wheels & tires, rear end gears
how much would my speedometer be off if i were to get mods such as different size rims & tires and rear end gears??
would it be a significant difference, or would it be okay in case i dont have enough money to buy a tuner, but still want to get these things??
RE: wheels & tires, rear end gears
is it real bad though or if your going like 70mph would it only be off like 3-5 mph or would it be like 10mph??
i could figure out which which way it was off and just drive according to that if its not off much.
All I know is on my Gt when it says I am going 90 im really going like 80 or so. After that speed it gets more and more off. If you do the gear do the speed calibrator. If your going to do it do it right! If you can afford it that is.[8D] I CANt haha
ORIGINAL: redv6pony
my 4.10's are off by as much as 10MPH[8D]still havent fixed it yet[&o]
if i am getting a 2000 v6 manual, which gears should i get(3.73, 4.10, etc.), and what is the difference in each.
also is there anything else i need to get with it.
and do i need to get an 8.8 inch rear end or will the stock v6 2000 work(which i believe is the 7.5 inch, correct me if i am wrong).
I think you should do a 373 on a v6. If it was a v8 then 410. You can use the same rearend. A tuner will not fix the speedomoter problem my man! You have to buy that calibrator. I may be wrong but i am pretty sure.
