spark plug help
Old 02-18-2007, 08:48 PM
thakodis1
thakodis1's Avatar
Default spark plug help
hey guys im about due for a tune up and this will be the first one i have done on my stang and i was looking a split fire spark plugs and i kinda like the design are these any good?
thakodis1 is offline
Old 02-18-2007, 09:06 PM
98ponycar
98ponycar's Avatar
Default RE: spark plug help
just stick with autolite platinums. i personally wouldn't use the splitfires in mine, but to each his own.
98ponycar is offline
Old 02-18-2007, 09:56 PM
cobra232
cobra232's Avatar
first question. how many miles are on the car??? if it's less than 60,000 then don't even worry about changing the plugs as all you are doing is wasting money. if it isn't misfireing then you don't need to change the plugs and wires. the 3.8 has a waste spark design which fires on the powerstroke and exhaust stroke which makes it very sensitive to plug failure. you will know when you need to change the plugs as it will run like it only has 4 or 5 cylinders.
if you want to change them anyways then just get the cheapest plugs you can get which would be Autolite 605's or 604's which are copper and excellent for blowers or turbo's. you don't need to spend alot on plugs and wires on stock engines. stock replacement wires are fine and copper plugs are fine too like the 604's delco R44LTS6's are a good plug too as are Champion RS12YC's. forget splitfire plugs. they don't make the engine go bang any better than regular copper plugs. coppers should be changed every 30,000 miles Platinum plugs autolite AP 764 or APP 764 only need changed every 80,000+ miles
never buy Bosch Platinums. they are complete junk. the center electrode wears out too fast on them
cobra232 is offline
Old 02-18-2007, 10:35 PM
raz54
raz54's Avatar
Split fires are the worst plugs ever made. I bought a set when they first came out & 3 out of the 8 were no good!!! Auto Lites or Bosch would be good.
raz54 is offline
Old 02-19-2007, 12:15 AM
kcjh23
kcjh23's Avatar
just as a tip don't buy autolites from walmart.. theres a reason that the same plugs are cheaper there than any car place.. when i bought mine four of them didn't work.. waste of $6
kcjh23 is offline
Old 02-19-2007, 03:25 AM
thakodis1
thakodis1's Avatar
so dont even go with plat copper are better
Old 02-19-2007, 05:25 PM
cobra232
cobra232's Avatar
ORIGINAL: kcjh23
nothing wrong with walmart plugs. i ran walmart autolit 604's with my blower with no problems. it the same damn plug that advance sells for $1 more
cobra232 is offline
Old 02-19-2007, 09:47 PM
90lxstang
90lxstang's Avatar
from my experience i have found that the copper autolites are the best and i run them on everything
90lxstang is offline
BOB ROME
07-26-2023 01:54 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
lmurf60
09-24-2015 10:07 PM
Quick Reply: spark plug help
