Looking to build sleeper. Most important mods??
Old 05-01-2007, 10:07 AM
nanaki
Retired MF Moderator
nanaki's Avatar
Default RE: Looking to build sleeper. Most important mods??
you won't have to worry about having a 400HP car with a 98. don't just do all suspension either. what good is having the ability to take corners if you can't accelerate out of them? if you're still in school, you probably don't have the funds needed to bring a 98 up to snuff. just enjoy the car as it is now and trade-up for a newer v6 or an older GT.
nanaki is offline
Old 05-01-2007, 10:10 AM
jthorn9
The Godfather
jthorn9's Avatar
ORIGINAL: nanaki
+1 NUFF SAID
jthorn9 is offline
Old 05-01-2007, 11:09 AM
deezelnut
I ♥ Acer
deezelnut's Avatar
ORIGINAL: jthorn9
OK first of all, you DO NOT want a single exhaust, it will cause you more problems than good.
can you explain this please???
deezelnut is offline
Old 05-01-2007, 12:49 PM
bhskins05
bhskins05's Avatar
if you plan on auto crossing, youll need to get a lsd
bhskins05 is offline
Old 05-01-2007, 01:00 PM
jthorn9
The Godfather
jthorn9's Avatar
Surely. Single exhaust is a lot of restriction for a car trying to make 300+ rwhp, not to mention 400, sure it's possible, because, hey, Skylines do it, but a Mustang is not a Skyline, and his car will work much better with true duals.
Also deezel, while we're on the topic, where the F are your pics. I thought you said you'd have them up in Jan, then again in March, here it is May, and still no pics, WTF gives man?
jthorn9 is offline
Old 05-01-2007, 03:46 PM
eddiev22
eddiev22's Avatar
a sleeper... keep your stock body, put in LT headers w/ dual exhaust and have turn downs after the mufflers, so nothing is showing... get auburn posi/detroit tru-trac (not tlok, they are weaker), get a twin turbo kit (have the exhaust built to it) and you'll most likely need new internals bc the stock engine isn't strong enough to handle over like 450-500hp stock i think... anyway, main point=twin turbo, if you have the money or can custom fab up a bunch of piping
eddiev22 is offline
Old 05-01-2007, 03:51 PM
amrcnidyot
amrcnidyot's Avatar
ORIGINAL: eddiev22
why the hell would you get longtubes if your gettin a turbo? youd just be trowin away the lts so you could put theturbo headers on. turndowns after the muffles will be loud, not much of a sleeper if its loud as hell.
amrcnidyot is offline
Old 05-01-2007, 05:09 PM
Adams_02GT
Adams_02GT's Avatar
1st mod, take the LED's off.Good luck with the project.
Adams_02GT is offline
Old 05-01-2007, 06:05 PM
eddiev22
eddiev22's Avatar
oops forgot i said LTs, iw as thinking just regular exhaust then my mind switched to TTs, and turndowns so you cant see the tips? do you want your exhaust fumes going into your rear axle? or is that not an issue
eddiev22 is offline
Old 05-01-2007, 06:17 PM
Crsytal Ice
Crsytal Ice's Avatar
ORIGINAL: Greenx98xV6
Well alright then, all things set aside, what would you all reccomend to make my car better for autocrossing. Should I go straight up suspension so I can corner harder, or just more horsepower.
Any luck a random turbocharger froma junkyard would work in my car? If it would what additional modifications would I have to make in order to apply the turbo?
not a turbo but u can score a supercharger off of a tnderbord super coupe...the superscharger off that will pretty much bolt on, need to do fab work of course
Crsytal Ice is offline
Quick Reply: Looking to build sleeper. Most important mods??
