Common Modification Parts List & Discussion
[align=left] Ok alot of people will get on here and say "What can I do for more Performance" Well I hope we can just give them all this information right away. These things will make you "go fast" They are the usual things. After you look through this list, then ask what you can do and what brands will be best. You can also read the other tech articals on specific brands, and exhaust clips! All these parts can be purchased through our site sponsers!! GL
First off,
Basic Bolt Ons:
TUNER
Cold Air Intake
Underdrive Pulley
Throttle Body (not much gains)
Headers (stock flows great)
Ignition Wires
Dual Exhaust
Suspension:
Springs
Shocks/ Struts
Control Arms
Rear Sway Bar
New Front Swaybar
Caster/Camber
Subframe Connectors
Tower Brace
Drivetrain
Gears (3.73M, 4:10A)
Locker
Shiftkit
Clutch
Lighter Flywheel
Short Throw Shifter
Engine:
Port&Polish Heads/Intake
4.2L Crank
Head Job
Other:
Mach 1 Grill
Mach 1 Chin Spoiler
Tint
Hood Scoop
Side Scoops
Bumper Inserts
[/align]
First off,
Basic Bolt Ons:
TUNER
Cold Air Intake
Underdrive Pulley
Ignition Wires
Dual Exhaust
Suspension:
Springs
Shocks/ Struts
Control Arms
Rear Sway Bar
New Front Swaybar
Caster/Camber
Subframe Connectors
Tower Brace
Drivetrain
Locker
Shiftkit
Clutch
Lighter Flywheel
Short Throw Shifter
Engine:
4.2L Crank
Head Job
Other:
Mach 1 Grill
Mach 1 Chin Spoiler
Tint
Hood Scoop
Side Scoops
Bumper Inserts
[/align]
RE: Basics (Stickey?)
OK, here it is for 94-98 Mustang V6s.
Air Intake
1.) MAC Cold Air Intake $170 @ autobadges.com
4.) 80mm Cobra MAF set to 24lb injectors
5.) 56mm BBK Throttle Body $249 @ V6mustangstuff.com
Engine
1.) ASP 25% Size Reduced Crank Pulley $72 @ autobadges.com
2.) Billet Aluminum Water Pump Pulley $65 @ rpmoutlet.com
3.) ASP Underdrive Pulley Belt $35 @ autobadges.com
4.) Diablo Predator Tuner 96-04 $399 @ hillbankmotorsports.com
5.) BBK Chrome Valve Covers $329 Silver $199 @ hillbankmotorsports.com
6A.) Stage 2 (AUTO) Powerpack $1725 @ supersixmotorsports.com
6B.) Stage 2+ (MANUAL) Power Pack $1950 @ supersixmotorsports.com
6C.) Stage 2+ (AUTO W/STALL) Power Pack $1950 @ supersixmotorsports.com
6D.) Stage 3 (FORCED INDUCTION) Power Pack $2375 @ supersixmotorsports.com
6E.) Basic Split Port Intake Swap Kit $720 @ rpm-mustangs.com
6F.) 99+ Stage 2 (AUTO) Powerpack $1800 @ supersixmotorsports.com
6H.) 99+ Stage 2+ (MANUAL) Power Pack $2200 @ supersixmotorsports.com
6I.) 99+ Stage 2+ (AUTO W/STALL) Power Pack $2200 @ supersixmotorsports.com
6J.) 99+ Stage 3 (FORCED INDUCTION) Power Pack $2350 @ ssms^^^
6K.) Split Port Swap Gasket Kit (no intake or heads) $310 @ rpm-mustangs.com
8.) 24lb Fuel Injectors $279, 30lb $275, 42lbs $359 @ jegsperformance.com
9.) Stud Mount Adjustable Roller Rocker Arm Kit $495 @ supersixmotorsports.com
10.) Cam Thrust Spacer Roller Bearing Kit $150 @ supersixmotorsports.com
11.) Spring Retainer Kit $225 @ supersixmotorsports.com
12A.) Forged Stock Internals $1200 @ supersixmotorsports.com
12B.) Forged H Beams W/ 351W Rods $1600 @ supersixmotorsports.com
13.) BBK Fuel Pressure Regulator $109.99 @ brothersperformance.com
14.) BBK 56mm Throttle Body $257.99 @ hillbankmotorsports.com
Forced Induction
1.) Nitrous Oxide approx $500 @ jegsperformance.com and many others
2.) Vortech Supercharger approx $3500, see vortechsuperchargers.com for info.
Ignition
1A.) Red/Blue/Yellow 9mm Spark Plug Wires $70 @ autobadges.com
1B.) Chrome 8mm Spark Plug Wires $100 @ autobadges.com
2.) see msdignition.com for the rest of your ignition needs
Exhaust
1A.) JBA Silver or Titanium Short Tube Headers $640.97 @ hillbankmotorsports.com
1B.) JBA Short Tube Headers $460.72 @ hillbankmotorsports.com
1.C) JBA Chrome Short Tube Headers $349.99 @ brothersperformance.com
2A.) 2.5†V6 O/R X-Pipe see pypesperformance.com
2B.) MAC 2.5†V6 O/R H-Pipe $160.50 @ hillbankmotorsports.com
2C.) 2.5†V6 High Flow Catted X-Pipe see pypesperformance.com
2D.) 2.5†V6 High Flow Catted H-pipe see pypesperformance.com
3A.) Magnaflow 2.5†GT Cat-Back Dual Exhaust $469.99 @ brothersperformance.com
3B.) Borla 2.5†GT Cat-Back Dual Exhaust $699.99 @ brothersperformance.com
3C.) Bassini 2.5†GT Cat-Back Dual Exhaust see bassini.com
3D.) Flowmaster 2.5†GT Cat-Back Dual Exhaust see flowmaster.com
4.) MIL Eliminators (for O/R systems only) $61.95 @ hillbankmotorsports.com
Drivetrain
1A.) Ford Racing Posi-Traction 7.5†Differential $199 @ v6mustangstuff.com
1B.) See drivetrainspecialists.com for more durable options
2A.) 3.73 Motive Performance Plus Gears $ 149.99 @ mustangtuning.com
2B.) 4.10 (Moderately Moded Apps Only) Motive Performance Plus Gears $149.99 mt
2C.) 3.73 Ford Racing Gears $199.99 @ v6mustangstuff.com
2D.) 4.10 (Moderately Moded Apps Only) Ford Racing Gears $209.00 @ v6ms
3.) Motive Bearing Kit $74 @ mustangtuning.com
4.) 23 Tooth Speedo Corrector -
Transmission Auto
1.) High RPM Stall Torque Converter see mustangsunlimted.com
2.) Shift Kit see mustangsunlimted.com
Transmission Manual
1.) Steeda Tri-Ax Short Shifter $179 @ autobadges.com
2.) Shifter Gasket Set $9 @ autobadges.com
3A.) Spec Stage 2 Clutch $333.95 @ mustangsunlimited.com
3B.) Spec Stage 2+ Clutch $399 @ mustangsunlimited.com
3C.) Spec Stage 3 Clutch $499 @ mustangsunlimited.com
Suspension
1.) Steeda Caster Camber Plates $229.95 @ autobadges.com
2.) Steeda Lower Control Arms $295.95 @ autobadges.com
3.) Steeda upper Control Arms $295.95 @ autobadges.com
4.) Steeda Lower Subframe Connectors $89.95 @ autobadges.com
5.) Eibach Pro Spring Kit $224.95 @ autobadges.com
6.) Tokico D-Spec Shocks $629 @ autobadges.com
7.) Ford Racing (Cobra) Break Kit $819.88 @ mustangsunlimited.com
8.) 17†or 18†Rims see tirerack.com
Side note, mustang forums does not recconize super six motorsports or their products as they refused to speak to our administration about becoming and official site sponsor since we send so much business there way. However their site is very good to check out, but any local machine shop can do the same work as them for a cheaper price.
Air Intake
Engine
Forced Induction
Ignition
Exhaust
Drivetrain
Transmission Auto
Transmission Manual
Suspension
And now onto the 99-04s
Air Intake
1.) MAC Cold Air Intake $170 @ http://www.autobadges.com/
2.)80mm or 90mm MAFset toneeded injector sizewww.mustangsunlimited.com(remember, this mod isn't necesary for all fuel injector modifications, only once 300 hp is broken as your stock MAF will adjust to the new injector size, some light tunine may still be needed)
3.) 70mm BBK Throttle Body $279 @ http://www.V6mustangstuff.com/
Engine
1.) ASP 25% Size Reduced Crank Pulley $162 @ http://www.autobadges.com/
2.) Billet Aluminum Water Pump Pulley $65 @ http://www.rpmoutlet.com/
3.) ASP Underdrive Pulley Belt $35 @ http://www.autobadges.com/
4.) Diablo Predator Tuner 96-04 $399 @ http://www.hillbankmotorsports.com/
5.) BBK Chrome Valve Covers $329 Silver $199 @ http://www.hillbankmotorsports.com/
6A.) Stage 2 (AUTO) Power Pack $1800 @ http://www.supersixmotorsports.com/
6B.) Stage 2+ (MANUAL) Power Pack $2200 @ http://www.supersixmotorsports.com/
6C.) Stage 2+ (AUTO W/STALL) Power Pack $2200 @ http://www.supersixmotorsports.com/
6D.) Stage 3 (FORCED INDUCTION) Power Pack $2350 @ http://www.supersixmotorsports.com/
7.) 24lb Fuel Injectors $279, 30lb $275, 42lbs $359 @ http://www.jegsperformance.com/
8.) Stud Mount Adjustable Roller Rocker Arm Kit $495 @ http://www.supersixmotorsports.com/
9.) Cam Thrust Spacer Roller Bearing Kit $150 @ http://www.supersixmotorsports.com/
10.) Spring Retainer Kit $225 @ http://www.supersixmotorsports.com/
11A.) Forged Stock Internals $1200 @ http://www.supersixmotorsports.com/
11B.) Forged H Beams W/ 351W Rods $1600 @ http://www.supersixmotorsports.com/
12.) BBK Fuel Pressure Regulator $109.99 @ http://www.brothersperformance.com/
13.) BBK 70mm Throttle Body $257.99 @ http://www.hillbankmotorsports.com/
Forced Induction
1.) Nitrous Oxide approx $500 @ http://www.jegsperformance.com/ and many others
2.) Vortech Supercharger approx $3500, see http://www.vortechsuperchargers.com/ for info.
Ignition
1A.) Red/Blue/Yellow 9mm Spark Plug Wires $70 @ http://www.autobadges.com/
1B.) Chrome 8mm Spark Plug Wires $100 @ http://www.autobadges.com/
2.) see http://www.msdignition.com/ for the rest of your ignition needs
Exhaust
1A.) JBA Silver or Titanium Short Tube Headers $640.97 @ http://www.hillbankmotorsports.com/
1B.) JBA Short Tube Headers $460.72 @ http://www.hillbankmotorsports.com/
1C.) JBA Chrome Short Tube Headers $349.99 @ http://www.brothersperformance.com/
1D.) BBK Ceramic Short Tube Headers $369.99 @ http://www.brothersperformance.com/
1E.) BBK Chrome Short Tube headers $269.99 @ http://www.brothersperformance.com/
1F.) MAC Long Tube Headers $269/50 @ http://www.hillbankmotorsports.com/
2A.) 2.5†V6 O/R X-Pipe see http://www.pypesperformance.com/
2B.) MAC 2.5†V6 O/R H-Pipe $160.50 @ http://www.hillbankmotorsports.com/
2C.) 2.5†V6 High Flow Catted X-Pipe see http://www.pypesperformance.com/
2D.) 2.5†V6 High Flow Catted H-pipe see http://www.pypesperformance.com/
3A.) Magnaflow 2.5†GT Cat-Back Dual Exhaust $469.99 @ http://www.brothersperformance.com/
3B.) Borla 2.5†GT Cat-Back Dual Exhaust $699.99 @ http://www.brothersperformance.com/
3C.) Bassini 2.5†GT Cat-Back Dual Exhaust see http://www.bassini.com/
3D.) Flowmaster 2.5†GT Cat-Back Dual Exhaust see http://www.flowmaster.com/
3E.) MAC Long Tube Catted H-Pipe $359.50 @ http://www.hillbankmotorsports.com/
3F.) MAC Long Tube O/R H-Pipe $169 @ http://www.hillbankmotorsports.com/
4.) MIL Eliminators (for O/R systems only) $61.95 @ http://www.hillbankmotorsports.com/
Drivetrain
1.) Ford Racing Posi-Traction 7.5†Differential $199 @ http://www.V6mustangstuff.com/
1B.) See http://www.drivetrainspecialists.com/ for more durable options
2A.) 3.73 Motive Performance Plus Gears $149.99 @ http://www.mustangtuning.com/
2B.) 4.10 Motive Performance Plus Gears $149.99 @ http://www.mustangtuning.com/
2C.) 3.73 Ford Racing Gears $199.99 @ http://www.V6mustangstuff.com/
2D.) 4.10 Ford Racing Gears $209.99 @ http://www.V6mustangstuff.com/
3.) Motive Bearing Kit $74 @ http://www.mustangtuning.com/
Transmission Auto
1.) High RPM Stall Torque Converter see http://www.mustangsunlimited.com/
2.) Shift Kit see http://www.mustangsunlimited.com/
Transmission Manual
1.) Steeda Tri-Ax Short Shifter $179 @ [URL=h
Air Intake
Engine
Forced Induction
Ignition
Exhaust
Drivetrain
Transmission Auto
Transmission Manual
