dpfe pipe manifold to exhaust broken
this pipe has two spuds for hoses to connect one has broken off think previous owner tried to change dpfe and pulled on hose. engine light on when i bought it. 94 convertible 3.8 auto. anybody know how to replace pipe I can't get wrench on bottom nut to remove looks like remove exhaust or remove a/c parts to get to.
RE: dpfe pipe manifold to exhaust broken
the bottom nut is a pain in the a$$ to get off. since your replacing it anyway though you can cut the pipe off right above the nut then put a socket over it. it would make it a ton easier
ORIGINAL: amrcnidyot
You could also do the cut and socket method too though since you're going to replace the pipe anyway though.
ORIGINAL: Derf00
it's not that hard Just get an adjustable wrench or channel lock wrench and a small 3 lb sledge. THe sledge method works best with the adjustable as it doesn't require you to keep the pressure on the handle to keep it from slipping. Get the wrench on there nice and snug and give it a few taps with the sledge to break it loose.
depends, the first time i took mine off it wasnt too bad, the 2nd time i did hit the damn thing w/ a hammer and it wouldlnt budge....damn thing is on there really good.
ORIGINAL: Derf00
got mine off with crescent wrench and hammer technique. That's a Craftsman crescent wrench, no cheapy wrench. I got to it because I had to change head gasket. I removed all theintake stuff, and O yes, I removed the hood. But I didn't need to removed any A/C stuff. worked from top down
easy fix. go to a junk yard and cut the section of the EGR pipe out that has the 2 lines coming off to the purgevalve. next cut your settl EGR tube with the broken section off and put the other in it's place and connect everything with the correct sized Emissions hose and 4 hose clamps
trashxtrash
09-20-2015 10:49 PM
TfcCDR
09-14-2015 12:08 PM
09-10-2015 08:39 PM
