Which gas do yall use?
#21
RE: Which gas do yall use?
ORIGINAL: HotRods_n_Booze
Ya, because 87 costs less and I'm an idiot...and plus 91 is a bigger number.
...oh, and I swear I get much better MPG on high octane. [sm=smiley24.gif]
EDIT: PS, I just remembered the real reason. My chip is programmed for high octane....so forget that other stuff I said before.
ORIGINAL: artisan00
any reason you arent going for the 87?
Super. 91 in Cali
Super. 91 in Cali
Booze, how did you get this done? Please PM me so I don't get accused of hijacking
#23
ORIGINAL: 2000iav6
I run 89 octane and it's gasohol (10% corn alcohol) because I like the fuel in my car to match the fuel in my body!
ORIGINAL: artisan00
Super. 91 in Cali
Super. 91 in Cali
#25
I personally don't think you should get a chip from VMP, I received my program from him, and it was terrible!! Also I use 93 octane for my setup. I have the SCT pro racer's package, so I tune my own car.
#28
87 octane takes less heat to ignite as oppossed to 91. Only need to run higher octane if you change compression ratio, add nitrous, supercharger, turbo or screw with timing, etc. All those things change the heat range in the combustion chamber and 87 will detonate before a spark is present (detonation booom). 91 octane can withstand more heat(less volatile) so it will wait for that spark.
