Phenolic intake spacer
RE: Phenolic intake spacer
ORIGINAL: WhitePony02
I'll ask my teacher, but using G10 seems pointless because 1. its expensive and 2. they don't make any of the intake out of G10 so regular metal should be fine.
And if its necessary to use G10, he can purchase it and it might even just charge the school. Last year in shop he didn't even charge anyone for their materials. I'll see, but since the CNC machines are free for me to use (there's two of them) and nobody ever uses them, I won't have to charge extra to get my money back for the CNC machine.
No, but I also wanted to point out that the OP didn't beat an 04 Accord unless it was a 4-cylinder model. The V6's put out 240hp and were just shy of running with stock GTs.
I see. I'm sure there's another alloy that I can make it out of that has good heat transfer properties and is cheap. Any suggestions?
The coupe auto V6 accord from 04 ran 15.3 in the 1/4 mile... The 330ci is heavier being a convertable with 225hp and 214lbs of torque.. the 330ci beat the accord when they finally clicked into fourth gear up till then it was a neck and neck race... They are both automatics. I have no interest in making up lies about who i beat aha. I actually beat the 330ci Automatic vert... i didnt get a chance to race the accord but it lost to the beemer anyways. I have no rear seats, no spare tire and i only weigh 160lbs, my gas tank was completely empty...i have the mods i listed in the other post and i consider my self i reasonably good driver. I dont even know how i made it home with my gas tank on empty tho [&:]... Yes i was surprized that i won... and as for the BMW being a bad driver, hes not and its an auto anyways, not THAT much too it. If it was a 6 speed 330ci NON VERT im sure i would have gotten pwned, but it wasnt. The automatic vert and auto versions of these cars are alot slower than their manual and hardtop counterparts... i have raced GT mustangs in these cars when my friends were driving and NO, they dont keep up with the GT's especially not from a dig. SO again i have no reason to be making this up, i dont know any of you...i just thought itd be nice to give some inspiration to V6 owners because it seems like many are beating themselves up about having the 3.8 and not the 4.6. What happened last night was an inspriration to me... because i had raced those cars before and LOST... when i had no mods and no weight reduction and i cudnt drive as well. I came home so happy i quickly sat down on the internet and started looking for more mods... because i want to be FASTA!!!
ORIGINAL: hpwrestler220
some people sware by them..it gives u a noticeable low end gain some say..im getting one soon..get it!!!
and can u post the site up??
get the 3/8 spacer...not the 9/16..there is no diffference i dont think. or maybe they do the exact same? idk. most people have 3/8
It may be more extreme for me because It's a 5.0L engine plus it's supercharged and on the bottle. So temp changes and longer runners make even more of a difference. But either way, I think they;'re great. And it cost me less than $70 brand new from summit.
Oh and lasserred38, your right about the hp it did have alot but
while the accord coupe auto did put out 240hp, it also only had 212lbs tq
and the beemer was heavier and vert and automatic- 225hps and 217lbs tq
read my whole post above and i think thigns well become a little more clear
And as for the phenolic spacers they do sound pretty, good but it says split ports can loose 1hp top end! AHHH. aha just kidding, if we get more torque and a little more hp for such a big part of the rpm band then i say its good. Im definately getting one. While im at it im gonna pulish my upper intake as well, maybe port if i have the right tools. I need to get new gaskets when i do this right??
ORIGINAL: Deepenough
ORIGINAL: laserred02
the point of using G10 is for its heat transfer properties. Metal will still allow the uppper intake manifold to heat up at the same rate, the phenolic keeps the upper intake cooler for a longer period of time. This is why if you have been driving for a long time some of the gains with the spacer are diminished because the upper intake is now hot, and there is no longer cooler air flowing into your motor. Metal intake manifold spacers are a waste of money.
