Newbie wants to take it to the next level
okay, so i am about to inherit my brother's car. it is a stock'06 V6 mustang. Like I said, its a stock autov6. *****, very ***** indeed. I want it to be faster, and a little bit louder (like a GT or a little more). I was thinking about installing a supercharger, but i've been told its not that easy, and yahtee yahtee yah. so i was hoping if someone on this forum will help get that jump start i need. i am a complete newb, but i am willing to learn. i am only looking for around 100-175 hp gain but not more
please help, all advice is greatly appreciated.
RE: Newbie wants to take it to the next level
The best thing to do would be to read all the posts you can. You will tell pretty quickly who knows their stuff around here and be able to sort through the b.s. But there is a ton of usefull knowledge on these forums, and some really smart people. And you're right, the only way you're gonna see gains like that are through forced induction. You might wanna live on the Pipes, boost, juice forums for a while, gathering all the knowledge you can. And when you are unclear about something then ask a question.
first your gonna need money, none of that stuff is cheap, and unless you know what your doing an S/C install can get messy... in a way forcing you to bring it to a shop which will make you pay a huge amount for "labor"
If your gonna go S/C then if it were me id work on my bottom end, if you just work the top end then youll eventually wear out the bottom and bad things will happen... Basically get the mods that will strengthen your engine enough for more compression.
How much would labor for a full sc install be? I havnt even thought about how much im gunna pay yet, and dont really care lol, but would rather know. Im talking about injectors, fuel pump, intercooler, tuner... the works!
Buy a used 6-8 psi supercharger, you'll save some cash, and unless the engine has been trashed, a 6-8 psi S/C will not put enough strain on the internals to blow them. Install difficulty all depends on your level of knowledge and willingness to learn about your car. It could be very easy for a pro, moderiately difficult for a person that learns quick with a manual and a little mechanical know how, and insanly hard for a blond that doesn't even know what a screwdriver does. That level S/C will get you fairly close to what you want power wise, then you'll need to do full exhaust to free up the engines abilty to "pass gas"when romping on the S/C, and a nice eaton, detroit, or auburn limited slip differential with 3.73 gears isn't a bad idea either.
ORIGINAL: jrhykushi
This can be especially helpful to know because not all the performance advice here applies to 05+ and vice versa....
(although a s/c helps in all years)
lurk in the 05+ forums. we're all trying to be helpful
-Joe
Good luck trying to find a used SC for an S197 V6. Explorer Express just released an M90 kit for the 4.0 V6. And trust me, you're starting off with a better platform than most of the SN-95 guys here...
