Pypes OR Xpipe LOW
Pypes OR Xpipe LOW
I ordered an offroad xpipe from American Muscle awhile ago and just had it put on my V6. I went up to chicago last weekend and I was having some serious problems with it bottoming out. So I took it back to the shop where I had it put on and they threw it up on the lift. Apparently the bends in that pipe just make it hang low. I double checked all their work and it is almost defiantely the pipe. Anyone else have this problem with one of these? I was going to lower it this weekend, but there is no way I can lower it with the exhaust as low as it is.
thanks.
thanks.
RE: Pypes OR Xpipe LOW
I have the Pypes Catted Xpipe and my cats hit sometime buts its because I lowered my car.......It want hit all the time I only hit when i go over tall speed bumps so I take them at an angle and they dont scrape you should be fine
mine hangs really low but wasn't put in by a shop, i just go over bumps and stuff at an angle and its fine, but if your going to have it lowered then i guess you would need to have something custom done to it or made for it if the reason isnt the install
jwog666
12-27-2021 08:09 PM
dalefrancis88
09-11-2015 07:15 AM
