how to remove center console
RE: how to remove center console
do u think i should do under dash or under seat or both, i have... 2 four inch led stips, 1 six light led pod, 1 six inch neon tube sitting around and i get the hookup on all that stuff so i can what ever i need.
put the 2 4" LED strips on either side under the dash, the LED pod under the dash behind the shifter facing toward the engine(just a thought, might look cool if its pouring light out either side) and the neon should be put on a shelf in your garage cause there is no place for it unless you get another one then put them under each seat. this is wat i would do but its all up to you, your car... your taste
Here I did a write up a while back. Someone said it was a waist of time and no one would ever need it...
https://mustangforums.com/m_4841279/tm.htm
Matthew
Matthew
