checkout the ripple effect
heard a weird noise while driving home from work so i pulled into a gas station .. back right tire looked low so i filled it up and what do you know ripple effect .. so i put the spareo n and drove home
question for you guys wtf causes this ripple effect? is it a bad tire ready to blow?
sorry about the bad quality its 1030 and f'in cold and dark out
Ok *cracking knuckles*
The indention all the way around the tire is called "run-flat" it is where the sidewall of the tire is "chewed out" due to (extreme) low tire pressure. The "ripple effect" is because your sidewall is so comprimised that it is trying to blow out. If you were to take your tire off the rim, you would see your sidewall in a powder form due to being gradually rubbed off.
Any other questions just ask. Hopw this helps. That tire is FINISHED by the way..
sIx .. yeah i had a blowout on some other tire i bought turns out they were 14 years old .. im just buying all new tires for the 94 and 96 im sick of hoping they are ok
95redv6stang .. lol yeah im not going to be using that tire .. and would that cause soft spots on the sidewall .. the blowout i had on a different set of tires u could feel the soft spots it was bad
granted you still have stock rims and tire sizes. Your tires will wear uneven if you just pump them up to the max also on long drive in the summer they will heat up and over inflate themselves
