cooling fan not working
Old 01-01-2009, 01:33 PM
jfdfire2
jfdfire2's Avatar
Ok heres an update...Turned control to A/C as suggested...fan came on, switched control back to defrost...fan stayed on, car idled for over 1 hr with no over heating with fan running. Drove car about for about 45 mins fan continued to run and temp stayed around N or O on gauge just like is always has. So I am guessing that means the coolant temperature sensor is bad. Sound right?
jfdfire2 is offline
Old 01-01-2009, 02:33 PM
red3.8_96stang
red3.8_96stang's Avatar
Lightbulb
If you have a DVOM, ECT is easily checked : http://www.fordfuelinjection.com/?p=28
However I'm betting it's the CCRM, since a faulty ECT would also cause noticeable driveability problems or bad fuel consumption, which you have not noted.
red3.8_96stang is offline
Old 01-01-2009, 03:27 PM
sIx
sIx's Avatar
I just replaced a bad ECT in my car, it did affect gas mileage a little bit, but it never cause it to run hot, or ever come close to over heating...
sIx is offline
Old 01-01-2009, 09:40 PM
red3.8_96stang
Depends how it fails, this device can send a high or low signal, if it sends a cold engine signal this could stop the fan from coming on when the engine is hot at low road speed or in traffic congestion. Also you can get the fan to come on with the A/C control since it overides the ECT in this event.
djbigskrilla
09-20-2022 01:04 AM
jdphillips73
08-16-2015 04:34 PM
Barcafut13
08-13-2015 08:05 AM
Barcafut13
08-10-2015 07:44 PM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: cooling fan not working
