ring and pinion ?
Uh, if you plan to auto-x, then 4.10's will suck and put you in a very difficult class. Get a rule book from whatever sanctioning body you plan to run with and pick a class according to your budget.
Just a little FYI, this is an install that, while straight forward, can not be performed without the proper tools and specs. If the gaps and shim settings are 100% right, say good bye to your rear end. So in short, have a shop do the work, if they F up, they pay for the repairs.
KingRando
10-02-2015 08:06 AM
