Rear Window Louvers
What do you drive SN197?? If so what kind did you get. Cause most that come with the 3m it should be pretty straight forward. Unless you got the roush one's then you'll have to cut the template out and make sure all the brackets are where they need to be and that the rite size tape is on the brackets aswell.
those are easy compared to the metal ones. Just do all your proper cleaning to the windshield. apply your 3m to the louvers at the tabs. get a buddy to help you. hold them above the window and get them lined up. Push down the top first slowly. If you get it right the first time, slowly lower the bottom portion while aligning, and push down. viola!
DreadPirateRoberts
09-26-2015 02:11 PM
wishinsky
09-21-2015 09:48 AM
09-16-2015 07:53 PM
