flow rate on 4.2 heads and 3.8s plz POSTED PICS
Old 04-15-2009, 04:42 AM
  #21
NeoTokyo
NeoTokyo's Avatar
Now another thing, if you use 1/2" or 1" phenolic spacer you wont have to modify your upper intake to clear the fuel regulator, you might even be able to clear a proper fitting F-150 fuel rail on there too.
NeoTokyo is offline
Old 04-15-2009, 08:01 AM
  #22
ramoyer1
ramoyer1's Avatar
i just threwaway a 98 windstar fuel rail dang it. That is the first tim ei have heard of them working. does it have a return line alrdy on it? and can i get some pics of your motor swap?
what is better mustang heads or the 4.2s? I know the 4.2 made a butt loads of ft lbs tq.
ramoyer1 is offline
Old 04-15-2009, 10:38 AM
  #23
jthorn9
The Godfather
jthorn9's Avatar
Nice advice neo, but as stated, those heads are still dirty, I wouldn't of taken them, I would of demanded that they finish the job. I don't have any old pics of my GT-40 X heads before I put them on the 5.0, but they were used, however fully rebuilt, and there wasn't a spec of dust on them, not to mention oil or dirt, when I got them.
jthorn9 is offline
Old 04-15-2009, 12:16 PM
  #24
l_shizzle_l
l_shizzle_l's Avatar
They are the same. The increase in torque comes from the longer stroke on the crankshaft, not the heads.
l_shizzle_l is offline
Old 04-15-2009, 01:22 PM
  #25
NeoTokyo
NeoTokyo's Avatar
The heads between the 3.8L and 4.2L are the same.
The windstar fuel rail does have a return line on it.
I think mine was a 98' if I remember correctly.
Here is one on ebay for $24.95 shipped, you cant get much better than that.
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
NeoTokyo is offline
Old 04-15-2009, 01:55 PM
  #26
ramoyer1
ramoyer1's Avatar
I will hit them with toothbrush and carb cleaner to finish them up. and from the pics i posted you can see the exhast ports are no were near the same size as my stock o1 heads.
I got my 2001 upper but i dont have a lower intake yet. so my question is what one should i use?
I will get pics of the motor and everything today.
ramoyer1 is offline
Old 04-15-2009, 02:41 PM
  #27
NeoTokyo
NeoTokyo's Avatar
take a ruller and measure the ports and compair, using the exhaust manifold gasket to check is just wrong!
The exhaust manifold gasket is huge by any term and you should never port match to that gasket size.
-Eric-
NeoTokyo is offline
Old 04-15-2009, 05:37 PM
  #28
ramoyer1
ramoyer1's Avatar
ok well i got
4.2 motor (no intake)
my 2001 upper intake
my 96 alt,ps,ac and waterpump.
NEEDED!!
5spd = 01-up or rebalanced 3.8 (0 or neutral) flywheel and a pilot bearing
01-up 3.8 oil pan
01-up 3.8 oil pick-up tube and screen
did i miss anything?
ramoyer1 is offline
Old 04-17-2009, 03:25 AM
  #29
NeoTokyo
NeoTokyo's Avatar
01+ valve covers as the 99-00 allowed a lot of oil back into the intake system.
I still have to change mine, not a big deal though as I plan on changing my lifters and rockers and getting a 2nd t-stat sending unit installed on the lower intake.
I dont know if the BBK valve covers have this problem though, in case your into those kind of things.
NeoTokyo is offline
Old 04-17-2009, 04:58 PM
  #30
ramoyer1
ramoyer1's Avatar
well i go the 4.2 covers still
ramoyer1 is offline
Quick Reply: flow rate on 4.2 heads and 3.8s plz POSTED PICS
