2000 3.8 litre thermostat issues - MustangForums.com
Old 04-23-2009, 10:23 PM   #1
dubarado
dubarado's Avatar
Default 2000 3.8 litre thermostat issues
So, my friend in her 00 sunburst gold v6 (prettttty car lol) overheated in traffic. I figure it's the thermostat cuz the car is getting up there in miles... what tools are needed to replace the thermostat? any other tips? I've never replaced a thermo before, but am mechanically inclined lol
dubarado is offline   Reply With Quote
Old 04-23-2009, 10:47 PM   #2
HamMach1
HamMach1's Avatar
Bump for the retard
HamMach1 is offline   Reply With Quote
Old 04-23-2009, 10:51 PM   #3
rmodel65
Yukon Cornelius
rmodel65's Avatar
first you need a hot knife to cut the old thermostat out, then we can talk about installing it
rmodel65 is offline   Reply With Quote
Old 04-23-2009, 10:57 PM   #4
stangant
stangant's Avatar
so easy just need a pair of pliers i use robogrip, pull the tension thing back and then the hose should come off. Once that is done you can pull the old one out and put the new one on... that simple. Although mine leaked so i put some of the sealant maker stuff on it and it is AOK.
stangant is offline   Reply With Quote
Old 04-23-2009, 11:32 PM   #5
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Make sure to get as much air out of the system afterword as possible. You can very easily get a air bubble in the cooling system when you replace the thermo.
Matthew
Matt's 95 Stang is offline   Reply With Quote
Old 04-23-2009, 11:46 PM   #6
rmodel65
Yukon Cornelius
rmodel65's Avatar
does a v8 thermostat look different from the vsex kind?
Old 04-23-2009, 11:52 PM   #7
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
If it were Rmodel, he'd just shoot it off, and hope not to hit his leg!
RyansQuick6 is offline   Reply With Quote
Old 04-24-2009, 12:13 AM   #8
rmodel65
Yukon Cornelius
rmodel65's Avatar
Quote:
no id use the plasma cutter duh
Old 04-24-2009, 12:21 AM   #9
moontang
moontang's Avatar
id just use his leg he shot offf
moontang is offline   Reply With Quote
Old 04-24-2009, 08:34 AM   #10
Acer2428
Site Mod
Acer2428's Avatar
Remove thermo. housing.
Pull out thermo.
Replace w/ new thermo
Use either gasket or gasket maker
Torque down housing
Let dry 24 hrs. if using gasket maker
Go
Acer2428 is offline   Reply With Quote
Finally drove 2015 Automatic w/ Ford Racing Handling Package, very nice. mungodrums The New S550 2015-2017 Mustang 7 09-29-2015 10:18 PM
O/R H pipe install car is now stalling when coming to a stop trashxtrash 4.6L (1996-2004 Modular) Mustang 4 09-20-2015 11:49 PM
01 Mustang Overheating :( MusicCity615 General Tech 7 09-12-2015 08:05 AM
No power from my 3.8 94stangnewbe V6 General Discussion 0 09-07-2015 08:39 PM
V6 Engine Ticking Nick Oliver V6 S197 General Discussion 2 09-05-2015 11:34 AM
04, 1994, 2000, 38, ford, fors, install, litre, mustang, problems, replace, thermostat, thermostats, tools, v6
