so i was putting on my steeda x2 ball joints and while taking the arm of i scratched the power steering rubber cover. I have still not turned the car on but a lil bit of power steering fluid came out. I am going to replace it wensday but should i drive it till then?
its an easy fix so i will see if my local part stores have it in stock. I seen that there was some sort of tube on the top, that should just slide off correct?
You have to pull the outer tie rod to replace it, do not, repeat, do not buy a "Split Boot", nothing but trouble. If you drive in a dusty area or you are getting this lovely rain that we have on the east coast, drive it sparingly, with that open, the polished portion of the rack is open to the elements. Just like any other hydraulic cylinder, crap/scratches/etc on the shaft is very very bad.
