Rear Rotor Replacement
Old 10-24-2012, 09:22 AM
  #21
jb721
jb721's Avatar
Originally Posted by ayrton02
You have to remove the bracket that holds the caliper on too. Remember to take some high temp grease to the sliding pins everytime you disassemble the caliper from the bracket as well.
Somebody told me I should replace the seals in the caliper while I'm in there. How easy/hard is that? I'm getting ready to do rear rotors, brakes, and front brakes this weekend and I don't have any experience working on brakes but I plan on grabbing somebody who knows what they're doing to help. Thanks
jb721 is offline
Old 10-28-2012, 04:21 PM
  #22
rbowmar
rbowmar's Avatar
Since the caliper slides side-to-side, if the sliding mechanism freezes up, the piston-side pad will wear very quickly. It was a mess when I took it apart, but my guess is that the previous pad changer neglected the high-temperature grease.
The brakes looked fine when I got the car 2 months before, but by the time I got home from my trip to RockyMountain National Park, the LR brake had ground through the pad backing plate almost to the piston!
rbowmar is offline
JonnyBlazeGT
11-03-2015 01:10 AM
Tyoung68
08-25-2015 04:31 AM
dba Brakes
08-23-2015 06:08 PM
dba Brakes
08-20-2015 11:03 PM
Daleford
08-10-2015 08:30 PM
Quick Reply: Rear Rotor Replacement
