Engine Misfire??? Please help!
Old 05-30-2009, 01:57 AM
5.0HOBOMB
5.0HOBOMB's Avatar
Angry Engine Misfire??? Please help!
Hi all,
I have a 98 stang v6 and I seem to have problems with my engine stalling real hard, but the funny thing is that it stops stalling all on its own. When it stalls hard the check engine light comes on so I decided to pull up some codes. At first it said that cylinder 1 is misfiring, so I decided to check the spark and spark is ok so now I think the problem may be the injector because it misfires for random periods of time. So after cyclinder 1 stoped misfiring for a while, it started all over again, but this time it was cylinder 6!!!!!!!!!!!!!!!!!!!
What could be the problem??? I really dont think I got 2 bad injectores right? All timing seems to work ok so I think maybe injector pulses are not working properly which leads me to believe something is wrong with the ECU.
What do you guys think, any input is appricieated!
5.0HOBOMB is offline
Old 05-30-2009, 08:53 PM
jthorn9
The Godfather
jthorn9's Avatar
Coil pack may be failing.
If that checks out then look at the ignition module (on the passenger side fenderwell, small 3" or so square box)
jthorn9 is offline
Old 05-31-2009, 01:51 AM
Blueper
Blueper's Avatar
Originally Posted by 5.0HOBOMB
Hi all,
Mine has lots of misfires and my father in law said to clean the EGR valve.
It corrected 95% of the misfires I had.
It's worth a try.
Blueper is offline
Nick Oliver
10-17-2018 04:22 AM
Omgitsa88Stang
10-05-2015 07:33 AM
bconboy
09-21-2015 12:52 PM
rksnow1
09-14-2015 08:46 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Engine Misfire??? Please help!
