please help - automatic transmission question?????????
im going off memory here but last time i checked the schematic from the auto trans the neutral safety switch was only in the starting circuit there's a separate switch that i believe is connected in with the brake switch.
Much thanks, Problem solved!!! Replaced the brake light switch and the fuse associated with the Stop lamp switch in the fuse panel under the steering wheel....It was blown also.....Maybe from the loose wire unsure, but all systems are go and she is back on the road for now...
mungodrums
10-07-2015 04:01 AM
