3.8 to 4.2 swap
Old 11-06-2009, 01:18 AM
bobby7821
bobby7821's Avatar
Smile 3.8 to 4.2 swap
Im building a 95 mustang for my son the cars in need of a motor i planned to rebuild the 3.8 but i,ve research a bit on the 4.2 what i gather is that there preaty much the same engine exept the 4.2 has a longer stroke but retains the same bore i plan on useing a m90 sc supercharger set up i bought the other day i have every thing to swap it to my sons 3.8 but if i can build the 4.2 and use the supercoupe heads than i should not have any problems my ? is are the blocks the same do they share all the same mounting points will the super coupe heads work any help would be great thanks
bobby7821 is offline
Old 11-06-2009, 02:32 AM
NeoTokyo
NeoTokyo's Avatar
They will swap over just fine.
The SC uses stronger rods and pistons though I beleive so you might want to think about updating that area too.
NeoTokyo is offline
Old 11-06-2009, 04:10 PM
LilRoush
LilRoush's Avatar
A well done single port M90'd 4.2L can put down over 400 rwhp.
LilRoush is offline
Old 11-08-2009, 01:43 AM
Waldron93
Waldron93's Avatar
should be fine.. your sons lucky.. i can only swap a 3.8 for a 3.8
Waldron93 is offline
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
mrappe
09-26-2015 10:16 AM
col2560
09-25-2015 08:59 PM
Quick Reply: 3.8 to 4.2 swap
