Squeak from wheel area
Old 11-11-2009, 10:56 AM
robinson209
robinson209's Avatar
Default Squeak from wheel area
I have a squeak coming from the front wheel area. The squeak gets worse when I turn the steering wheel to the right or left. Seems to be fine when the steering wheel is straight.
robinson209 is offline
Old 11-11-2009, 11:14 AM
Shaunmac9128
Shaunmac9128's Avatar
Tie rod, some bushing? Just some guesses not sure.
Shaunmac9128 is offline
Old 11-11-2009, 04:47 PM
sabin_chicago
sabin_chicago's Avatar
got the same problem
didn't figure it out which one it is, but I guess it can be the tie rod or the ball joint
sabin_chicago is offline
Old 11-11-2009, 06:06 PM
fordforlife0225
fordforlife0225's Avatar
if its the front wheels it is mostly the BALL JOINT
fordforlife0225 is offline
Old 11-11-2009, 07:14 PM
Shaunmac9128
Yeah but he put X2's but I doubt they would wear out that fast...
Old 11-12-2009, 12:17 PM
Fink
Fink's Avatar
Are X2`s greasable? If they are grease them.
Fink is offline
Old 11-12-2009, 02:14 PM
robinson209
This chirpy noise is definitely not the balljoints. I know the sound they make, and this is not that sound. Besides, they are brand new Steeda X2's.
The noise has that sound of a squeaky wheel on a shopping cart. As you move the cart faster the wheel starts chirping faster.
Also, when the windows are down, it sounds like it's coming from the drivers side.
Here is what we know so far:
-the noise is coming from the drivers side wheel area (or possibly from the engine bay?)
-it sounds like a chirping shopping cart wheel
-the rate of the chirp is dependant on the speed I am going
-turning the wheels seems to provoke the chirp
I would just take it in to have it checked; however, money is tight right now. I appreciate all the help I can get.
Old 11-12-2009, 03:19 PM
neo8222
neo8222's Avatar
time to rebuild the hub
neo8222 is offline
Old 11-12-2009, 04:09 PM
Fink
Fink's Avatar
Are the hubs able to be rebuilt on our cars? I know most of the cars today have hub assemblies that cant be rebuilt.
Fink is offline
Old 11-12-2009, 04:17 PM
Clif Brohn
Clif Brohn's Avatar
He got the punch first, but like Fink said, late model mustangs use a hub with built in bearing. Although its possible to remove and replace the bearing FROM the hub, chances are the hub itself is also worn so....replace the front hubs. Easy way to check this is to go out to your car and firmly wiggle the wheel from the TOP of the tire. Any noticable wheel play that isnt just the car rocking back and forth is bad and indicates worn bearing/hub. Also excessive steering wheel play is an indicator of worn bearing/hub action
Clif Brohn is offline
Quick Reply: Squeak from wheel area
