100k recommended tune up stuff? - Page 2 - MustangForums.com
Old 01-15-2010, 03:31 PM   #11
mustangman02232
mustangman02232's Avatar
Quote:
Originally Posted by RyansQuick6 View Post
One thing we would do on a dodge trans is that you drain the fluid out, BUT you put in a 50/50 mix of new and old fluid, puting in all new fluid messes it up. This was actually the recommended procedure from Chrysler.
since when did chrysler become trans experts? my buddies ram is the only vehicle ive ever known to leave a dealership lot brand new with a leaking trans and needing a rebuild as a 5k mile service.
what does your fluid look like when you check it?
mustangman02232 is offline   Reply With Quote
Old 01-15-2010, 03:47 PM   #12
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
My fluid looks pretty, because I have a stick lol
RyansQuick6 is offline   Reply With Quote
Old 01-15-2010, 03:55 PM   #13
03gt04mach1
03gt04mach1's Avatar
Quote:
Originally Posted by neo8222 View Post
yeah multiple fuild drops and filter changes are better than a flush. so a fluid and filter change then like 5K miles later do it again and it'll be better than a flush.
That's what I was going to say. I use to rebuild transmissions,'till Bladder Cancer got me. With dropping the pan, you can gain access to the filter. And BELIEVE me, they do need changing. Flushes never can do that.
03gt04mach1 is offline   Reply With Quote
Old 01-15-2010, 04:02 PM   #14
03gt04mach1
If you do fluid changes by dropping the PAN, most of the fluid is still in the Tourqe Converter anyway. I don't understand that logic...50-50? Maybe that's why they have so many transmission issues. There's more OLD fluid than NEW. So what's the purpose behind the fluid change?
Old 11-09-2013, 04:53 PM   #15
JayMax03
JayMax03's Avatar
Default 04 3.9L Tune Up?
Hey to all I'm coming up on 93,000 miles and haven't had a tune up yet? What all do I need to do? Plugs, wires, coil pack, and what else that's needed? This is my time doing something major so I want to get everything out of the way. The only reason I figured I needed a tune up is my "check engine" light is on and its skipping while I'm driving. Is there a tune up kit that comes with everything I need instead of buying everything separate?
JayMax03 is offline   Reply With Quote
Old 11-11-2013, 04:20 PM   #16
03gt04mach1
If you pull and check the Dip Stick, you can look over the fluid on it. If it still has a red color and not a grayish color, and doesn't smell burnt you'll be fine changing the fluid. The Filter should be changed with it. I HATE Flushes also. They don't change the filter either when they do them. And the Filter is very important. So, check the Dip Stick. it will tell you a lot.
Old 11-11-2013, 04:50 PM   #17
mustang racer06
Shaunmac9128- Have u flush out the coolant? Maybe replaced thermostat? Just something to be aware of if u havent done it in awhile
mustang racer06 is offline   Reply With Quote
Old 11-11-2013, 04:56 PM   #18
mustang racer06
JayMax03- those are all things that should be done in a tune up. If the CEL is on, what code does it say? If u dont know, go find out just to be sure its something (like a misfire) that can be cleared up with a tune up. (pepboys scans for free) In addition to what u said, as what was previously said, do the oil+ filter change and fuel filter. Give a check or flush out the engine coolant if u havent done it in either 4-5 years of if u bought the car and have no prior knowledge to if it was done or not. If u flush it, change the thermostat out for the extra $5-$10
Tune with a stock air box mapitts 5.0L GT S550 Tech 49 05-15-2016 03:57 AM
Tuned Mustangs Battle for Street Racing Cash MustangForums Editor Street/Strip 5 09-08-2015 07:25 PM
Steeda & Nitto Tire Testing NT555 G2 - Great Photos Inside!! tj@steeda Steeda Autosports 0 09-08-2015 12:50 PM
AM or Bama please comment whatsup62 5.0L GT S550 Tech 1 09-03-2015 02:38 PM
100k, 2000, 2001, 2002, 2005, car, cost, f150, gt, maintanence, maintenance, mustang, service, tune, tuneup
