100k recommended tune up stuff?
Old 01-14-2010, 11:22 AM
Shaunmac9128
Shaunmac9128's Avatar
Default 100k recommended tune up stuff?
Well I'm at 99,000 miles now and going back to school in a week without the car so it will be sitting for a little while but I'll have the parents drive or at least start it weekly. I've done the normal stuff like fuel filter, new plugs, wires, seafoam, regular 3,000 mile oil changes but is there any other stuff I should do as far as a kind-of 100k tuneup? I was thinking I should get my trans flushed since its recommended like every 30,000 miles and I don't know the last time it was done. Should I go to ford or the Valvoline place I usually go to who's running a special? I was also thinking of doing the 02 sensors. There are 4 correct? Would either two be better to replace or should I just do all 4 and any brand recommendations? Any other ideas just as regular maintenance and good tune up stuff? Thanks guys.
Shaunmac9128 is offline
Old 01-14-2010, 11:49 AM
ESG-642T
Buyer Beware
ESG-642T's Avatar
If the 02 sensors aren't going out no point in replacing them, plugs, wires, sea foam, change oil, and it should be fine. If you have an auto and haven't flushed the trans don't do it now.
ESG-642T is offline
Old 01-14-2010, 12:50 PM
Shaunmac9128
Well I've only had the car for just over 15,000 miles and I don't know when the previous owner did it. You think it would be a bad idea to have it flushed and put some fresh fluid in?
Old 01-14-2010, 02:56 PM
sIx
sIx's Avatar
?explain please?
sIx is offline
Old 01-14-2010, 05:14 PM
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
I wouldn't do a flush, I'd do a drain, filter change and then refill. All a flush does is pump all the nasty crap backwards through the tranny
RyansQuick6 is offline
Old 01-14-2010, 06:44 PM
ESG-642T
Buyer Beware
ESG-642T's Avatar
I don't know if I would do that either ryan, that nasty crap may be holding the trans together.
ESG-642T is offline
Old 01-14-2010, 08:14 PM
Shaunmac9128
Yeah thats what I was worried about. Damn, now I can't decide. It would be like $130 saved if I don't do it.
Old 01-15-2010, 10:26 AM
sIx
sIx's Avatar
I changed my tranny filter and about 6 qts of fluid for the first time at 117k and 'so far' (knock on wood) I have had no problems... at 144k now
sIx is offline
Old 01-15-2010, 11:05 AM
neo8222
neo8222's Avatar
yeah multiple fuild drops and filter changes are better than a flush. so a fluid and filter change then like 5K miles later do it again and it'll be better than a flush.
neo8222 is offline
Old 01-15-2010, 01:33 PM
RyansQuick6
Reverse Gear Member
One thing we would do on a dodge trans is that you drain the fluid out, BUT you put in a 50/50 mix of new and old fluid, puting in all new fluid messes it up. This was actually the recommended procedure from Chrysler.
Quick Reply: 100k recommended tune up stuff?
