4.10 rear end gears + t-lok
Old 04-08-2010, 01:49 PM
KPOD
KPOD's Avatar
Default 4.10 rear end gears + t-lok
I was looking over this article, seeing as how I have a V6, I don't feel like dropping a whole lot into it. I figure if I'm gonna spend more than $500-600, I might as well sell it and get a GT or save for a Cobra. So my thoughts were I'd have the most fun from upgrading the rear gears to 4.10 and a t-lok. Now my question is, if I upgrade these 2 things are there any other components that I really should upgrade at the same time? It is an auto, and that guide talks about transmission coolers. Or would I be alright with everything the new rear gears and t-lok running with everything else stock? Thanks
KPOD is offline
Old 04-08-2010, 01:54 PM
Shaunmac9128
Shaunmac9128's Avatar
You can run everything else stock. Don't forget installation costs. A transmission cooler is just a good idea because your tranny will be shifting more due to the quicker gears.
Shaunmac9128 is offline
Old 04-08-2010, 01:55 PM
KPOD
KPOD's Avatar
The local Mustang club has some great guys that are willing to help with the install. How much do transmission coolers run?
KPOD is offline
Old 04-08-2010, 02:10 PM
Shaunmac9128
Under $100. They should be able to help you install that too. Wouldn't be a bad idea. B&M has one, look it up.
Old 04-08-2010, 09:00 PM
WoahPony
WoahPony's Avatar
You're going to either need a Speed Cal spedometer corrector, the correct plastic speedo gear, or a tuner to fix the spedometer. I'd suggest the tuner Xcal or Diablo) Just so you'll get more out of the mod, but that'll run you another ~400 dollars
WoahPony is offline
Old 04-09-2010, 11:33 AM
KPOD
KPOD's Avatar
I'm sure between these guys, one of them must have a speedometer corrector. But I'll keep that in mind when inquiring to them.
KPOD is offline
Old 04-10-2010, 12:28 PM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Tunner are locked to one car. So I dont think anyone will be able to correct your speedo with their tuners, just a FYI
Matthew
Matt's 95 Stang is offline
Old 04-10-2010, 12:31 PM
WoahPony
WoahPony's Avatar
maybe he means a speedcal, but your best bet is to buy the correct gear ratio speedo crrector. its a little plastic gear you can buy. pretty sure late model resto has them
WoahPony is offline
Old 04-10-2010, 12:43 PM
Matt's 95 Stang
Resident Ginger
Yes they do but you will have to call them and ask them what color to get for the 8.8 4.10's as they dont list that on their website.
Matthew
Old 04-10-2010, 05:03 PM
WoahPony
WoahPony's Avatar
Do the '94 - '99 have an 8.8" rear end?
WoahPony is offline
Quick Reply: 4.10 rear end gears + t-lok
