Climate Control knob issue
Climate Control **** issue
Hi,
My climate control **** does not seem to work anymore on my 1996 V6 Ford Mustang.
Even though I switch it to Vent, Floor, Mix or AC, the air is still coming out like the setting is on defrost.
I checked my fuses, but did not see anything wrong.
Any ideas?
Thanks
Any ideas?
Thanks
Same thing happen to me. Under the hood, right next to the firewall on the drivers side there is a vacuum tree. Check the smallest line running into that tree, mine broke and caused the air to go to the defrost. I replaced that line and everthing went back to normal.
Matthew
Matthew
That was the problem, the vacuum line was not connected to the rubber connector anymore ...
What I did not know is that this is also used for the brake, I just had to use more force to apply the break on my way to Autozone.
Thanks
Thanks
LivingInThePast
09-16-2015 12:20 PM
