does the abs sensor affect traction control?
Old 07-15-2010, 07:28 PM
snowmobiler7c
snowmobiler7c's Avatar
Default does the abs sensor affect traction control?
I just pulled apart my right rear axle to do a axle seal. When pulling it apart i tried to remove the speed sensor from the backing plate to let the axle move in more to the diff to make it easier to remove the c clip, and must have ruined the sensor. When i pulled the car out of the garage the abs light came on and then when i looked down the traction control off light was on. So Would the abs have anything to do with the traction contol being off? Also anyone know how to remove the abs sensor? I removed the bolt and then ruined it trying to remove it any tips? thanks
mark
snowmobiler7c is offline
Old 07-15-2010, 08:09 PM
Boost Logic
Banned
Boost Logic's Avatar
That ABS sensor is responsible for the traction control, i do know that.
As far the rest not sure dont got a mustang yet. Check a manual or
just goggle abs speed sensor for 19 whatever ford mustang.
Boost Logic is offline
Old 07-15-2010, 08:48 PM
snowmobiler7c
ok good i was worried something else could be wrong also. The haynes repair manual dont go into any specifics on replacing a wheel speed sensor i just ordered one from rock auto for $50 shipped to my door. Now just have to figure out how to get the old one off and new one on. car is a 2001 thanks
Old 07-15-2010, 08:53 PM
Boost Logic
Banned
I saw that one dude had a mechanic who fried his caliper with a torch in attempt to loosen it up and actually just fried his abs wire without knowing somehow. Traction control light came on. Use this as a guideline.
http://www.youtube.com/watch?v=L65kzq2tFnY
jwog666
12-27-2021 08:09 PM
mrtrodonet
09-19-2020 03:12 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: does the abs sensor affect traction control?
