Mac Long tube headers
im about to do my long tube headers on my car are there any things i should prepare for or anythings i might need to know to make this easier, and one other question are u still able to reinstall ur egr system on the headers?
Ryan suggested taking off your upper intake to make it easier but I never did.
Check for clearance with the starter, some guys have had problems with this.
There should be a threaded bung for the EGR on one of the primaries.
make sure your easy on the header studs, dont break one off in the head
the egr bolt on the header can be a bitch getting at with a wrench, it might be possible to run the egr pipe back on and tighten it with the header not bolted up yet and hanging down, not sure but if i was to do mine again i would definitely try that to make life easier.
make sure you have the o2 sensor extendors
make sure you have MILS or a tuner that turns off the rear o2 sensors
the long tubes should be able to get shoved up from underneath, not from the top
and obviously take out the intake tubing to clear up room to work
thats all i can think of, have fun and i know you will love the new sound
