Terrible gas mileage, please help?!
#21
hey, hate to burst your bubble but when you have a cracked header, exhaust gas leaks out and air bleeds in, thats an exhaust leak, so wouldnt it stand to reason a cracked manifold/header is a exhaust leak?
#23
okay so, we ruled out a few things. we went to a place and they checked the vacuum hose, checked for any leaks and there is no fuel leaking from anywhere and my exhaust is all fine. BUT there is a teeny crack where the header (manifold) connects to the engine (i dunno, w/e it connects to) and you can barely see it from where you look inside the engine bay. they said they can take it off and weld it but that it's such a tiny leak that when my car heats up, it expands and won't leak, it's only when my car is cold?? so that wouldn't be the problem for this fuel problem. my check engine light bulb is fine too, cuz when i go to start the car, all my lights come on, so it's not a blown bulb. so what we're looking at now is ....
a) faulty mass airflow sensor?
b) faulty o2 sensor?
c) fuel pressure problem?
any other ideas of what it could be? thanks!
#24
Your leak can still be causing problems. Usually it's a crack on the side of the manifold you can't see along the collectors. I couldn't even see my cracks because they were so small, but they had a profound effect on my mileage and the way my car would run.
You can try to replace the O2 sensors, but I doubt it if would make a difference. I don't think it's a fuel related problem unless an injector is stuck.
#25
okay, so i will get that leak fixed asap when i get some $$$$. and my b/f is going to crawl under my car tomorrow and take a look at the o2 sensors and see if they're dirty or look bad. i'm really hoping it's not a fuel injector because to my knowledge, that's something hard to diagnose and expensive to fix? thanks again
and also, if i were to go and find the o2 sensors look bad, would these be the right ones to buy for all 4?
http://www.car-stuff.com/carparts/fo...t=SEO+Page%3A1
#27
#28
you're selling yours? how much? haha
well that sucks about the sensors... so you think i should just replace the front ones first, see what happens and if that doesn't work, replace the back ones? and why the front ones first? as far as i know, they've never been changed, and i'm at 116,000kms at this point. thanks
#29
I am having a P0401 EGR fault on my 2001 3.8L, I've replaced everything but the pipe for the EGR system. But the stupid EGR insufficien flow fault keeps popping up. I have brand new short tube headers and catted X-Pipe for a true dual system on my car. Please help if any ideas, I am getting so frustrated!!!
#30
