Driver side window scratching
The outside of my driver side window is starting to scratch from opening/ closing the window. I have a 2001 model, so perhaps the outside felt needs replacing? I had the inside felt wrapped latches already replaced, and doing so did nothing to alleviate my problem. The window is only 3 years old and it looks far worse than my passenger one which is nearly 10 years old. Because of this I have refrained from using my window unless absolutely necessary.
The scratches occur on the OUTSIDE and not on the inside to the tint.
Any ideas?
Any ideas?
The outside felt needs to be cleaned or replaced. Or there is something on the inside of the door that is coming in contact with the window as it goes up/down that is causing the scratches.
I would start by checking out the felt first… Most likely its just got some dirt or something in it that is scoring your windows. Simply cleaning it should fix the problem. However, if the felt is worn away then it needs to be replaced.
Good luck...
Good luck...
I'd say the best way of getting exactly what you need as soon as possible would be to just go into your local dealer and ask for it. They might have it in stock and if they don't, they'll have it within 2-3 days probably. Especially with a cheap part like that, that's what I'd do.
I'll go by a dealership next week to purchase the felt.
I have another issue related to that window.. has anyone ever had a window sanded, or whatever the terminology is, to remove very minor, fine scratches? My driver side window has many scratches, but all of them are extremely shallow. The window is less than 3 years old, and if this method cost less than the cost of a new one, I'd gladly go that route.
I was wondering where I can get this done, as there is no place that does it in my city. I am close to San Antonio, though.
09-08-2015 11:50 AM
