Confused over exhaust clamps
Hi, I have a 2000 3.8L, I'm replacing the H-pipe on it now with a Jegs 2 1/4 H-pipe and Magnaflow Cats. I want to have a versatile setup so that I can remove the cats every once in a while and then put them back in.
The h-pipe is a true 2 1/4 but the cats inlet/outlet are a little random between 2 1/4 and 2 1/2. Because of this the H-piping fits into the cats, so I don't think a flat butt clamp will work. I would probably need a lap joint but then when I put the straight pipe back on I would probably need a butt clamp.
What's the best kind of clamp to use in this situation, as I'd rather not have to buy 8 total clamps (four butt for straight piping and four lap joint for cats). I also see Jeg's lap joints say that they're not supposed to be re-used, once removed.
Thank You
Thank You
mrappe
09-26-2015 10:16 AM
09-24-2015 09:18 PM
