Shop installation incorrect? Misdiagnosis? - Page 3 - MustangForums.com
Old 02-06-2011, 09:09 AM   #21
03shadow
03shadow's Avatar
Quote:
Originally Posted by NeoTokyo View Post
Yeah I hope that fixes it.
You really ought to change mechanics though if he was so blind as not to double check the part. If you look at them you will not mix them up.
Sounds like he just wanted some extra money from ya.
yeah thats what i was thinking at first. if he is a family friend mechanic then hes probably just dumb lol
03shadow is offline   Reply With Quote
Old 02-06-2011, 09:47 AM   #22
PNYXPRESS
PNYXPRESS's Avatar
Went back and reread your first post. Every engine Ive pulled apart and rebuilt, there is a crankshaft behind the harmonic balancer not a balance shaft as your "mechanic" told you. You may want to look for a new mechanic as I would be questioning this guys skills.
PNYXPRESS is offline   Reply With Quote
Old 02-06-2011, 10:24 AM   #23
NewEdgeStang00
NewEdgeStang00's Avatar
Yeah he printed me out an engine diagram and everything and showed me the balance shaft sleeve connected to the HB, then it hit me the other day that I should check into it myself and looked for pics online, it looked totally different. So I asked ford for an engine diagram and I immediately recognized the part, and it sit above the crankshaft, and they said it would take an INCREDIBLE amount of force to damage or crack that piece.
NewEdgeStang00 is offline   Reply With Quote
Old 02-06-2011, 02:55 PM   #24
NeoTokyo
NeoTokyo's Avatar
Well its not the shaft itself that can get damaged, the gear driving it can but then you would suffer many other problems.
NeoTokyo is offline   Reply With Quote
Old 02-06-2011, 04:07 PM   #25
NewEdgeStang00
yeah if it was the gear that was damaged I'm sure it would cause a lot more problems than just the car shaking right? I would imagine it would be a lot more noticeable.
Old 02-06-2011, 08:40 PM   #26
NeoTokyo
NeoTokyo's Avatar
If the gear broke the car wouldn't run. :P
All that shrapnel and slop would gaul and jams things up damn near instantly.
If you look at some engine build pics you will see how the shaft is driven, a failure in those parts would not be a good thing.
When I offered to buy your car I just figured I would replace the motor ($5oo or so) and take the other one apart to see what was up with the vibration and rebuild it as a 4.2L
I felt that it was probably something more serious because I was considering the obvious cause to be fixed (Dampener) but if they sent you the wrong one then of course that would be the problem. :P
If this still doesnt fix you problem, just let me know and we can try to work something out.
Old 02-06-2011, 10:19 PM   #27
NewEdgeStang00
Thanks man I will let you know! And yes I'm pretty sure (for the most part) that its just the harmonic balancer because before I replaced it the car shook noticeably but when the new one was installed it was bad enough that it shook the snow off my car. So I'm thinking the correct balancer will have it running good again (hopefully!) If not then I'm more than happy to work out a deal with you
Old 02-07-2011, 07:26 AM   #28
LilRoush
LilRoush's Avatar
I think it will fix the problem. I've had the wrong bal on and it feels just like what he's describing. Same thing with the wrong flywheel.
LilRoush is offline   Reply With Quote
Old 05-09-2014, 05:25 PM   #29
steve987fix
steve987fix's Avatar
Quote:
Originally Posted by PNYXPRESS View Post
yes there is a balnce shaft, but it is up high in the block between the heads above the cam shaft.
Looks like you have a leak in your intake manifold or manifold gasket between the coolant and the #6 forward intake port. This port is clean while all the others have some soot in them.
I know: "Thank you, Captain Obvious!"
steve987fix is offline   Reply With Quote
Old 05-09-2014, 06:24 PM   #30
BabyGT
BabyGT's Avatar
If he hasn't found that leak in nearly two and a half years I don't think it matters at this point...
BabyGT is offline   Reply With Quote
2015 Mustang Expansion Tank Granatelli Sales The New S550 2015-2017 Mustang 20 03-16-2017 07:33 PM
AODE Woes Pyrate Dave 5.0L (1979-1995) Mustang 8 09-10-2015 07:30 PM
First Mustang 99' 3 differnt body kits installed TimeLord101 New Member Area 3 09-04-2015 09:27 AM
New member and just bought my first mustang Luke9222 New Member Area 7 09-04-2015 06:46 AM
Help! Metra 70-5521 AMP Harness Install cbird1177711 2005-2014 Mustangs 2 09-03-2015 08:43 PM
2000, 289, 38, balance, balancer, engine, ford, harmonic, install, installation, misdiagnosis, mustang, semptons, shaft, shop, slipped, time, v6
