Hello everyone, I am new here to MF, I have an issue with my 1994 v-6 mustang, have miss fire on cylinder 6, replaced wires, plugs, ignition coil pack, fuel filter and injector #6, all others are good, checked compression it is at 150, someone told it could be the computer not sending signal to that particular injector or keeping it wide open, i tend to beleive the later, due to that i have a lot of white smoke from exhaust, please help, thanks in advance
thanks, but I was first trying to get some feedback, is that the best you can come up with thans but no thanks, anyone else have any ideas, common thats one of the reasons i singed up here for advice
my car miss fires when started but it goes away shortly and it blows white sweet smelling smoke from the exhaust and the coolant goes somewhere but not is my oil or anything..i cant find it.
Head Gaskets are a relatively common problem on these motors... I had a leaking head gasket on the driver side, but it had perfect compression... just consumed coolant at a very slow rate...
