Replacement 3.8L V6?
Old 04-30-2011, 11:39 PM
NeoTokyo
NeoTokyo's Avatar
Well I think $1100-1200 isnt that bad for the upgrade, but it does come down to what you can afford.
I also would not take their word that the engine has only 24k on it, always ask for a confirmation on the odo (A picture), most will not be able to give this to you though and they will say that the car is long gone and the engine has been stored for a while or something around those lines.
Low mile 3.8's are very hard to come by.
NeoTokyo is offline
Old 05-26-2013, 05:28 PM
bbbilly426
bbbilly426's Avatar
I have a 95 3.8l. Blowed the head gasket on it. I found a 2001 3.8 in a Mustang for 300 buck what should I do any help would be appreciated. My wife really love this car. How hard would swap be and do I need anything special for the swap
bbbilly426 is offline
Old 05-26-2013, 08:40 PM
jthorn9
The Godfather
jthorn9's Avatar
^^^Did you not read all the responses here, your question has already been answered. In fact, I answered it on page 1.
jthorn9 is offline
Old 02-10-2015, 05:47 PM
lightning31659
lightning31659's Avatar
Originally Posted by jthorn9
Actually 94/95 v6s were slightly different than 96/98 V6s which are different from 99/00 V6s, which are different from 01/04 v6s and late 04s have a different V6.
In a nut shell they are all interchangeable with each other. They all use the same motor mounts, same install procedure and what not.
For a direct swap you need a 96/98 V6. The 94/95s use OBDI technology and EEC IV ecus. So they are setup a little differently than a 96+ that are all OBDII EEC V technology. Any 99-04 V6 will swap in, however you need the entire engine (oil pan to the air intake that goes into the fender well), the wiring harness, and the ECU. As they use a different air intake setup, different wiring harness, and ignition system (mainly spark plug wires and coil pack location and setup, should come on the new motor).
Also keep in mind that 94/95 and some early 96 Mustangs had severe head gasket failure problems. While all 94-04 Mustangs are prone to head gasket failure due to the difference in metals in the heads and the block, the 94/95s were more prone than any other year. In middle 96 Ford made better gaskets that dropped the failure rate, but not completely.
1995 3.8l mustangs are obd2
lightning31659 is offline
Old 09-23-2015, 02:10 PM
Ghost_Conscience
Ghost_Conscience's Avatar
I know this this thread is old but.... Thats not entirely correct, early 95's were OBDI, ford switched over to OBDII sometime in late 95.
Ghost_Conscience is offline
Old 09-24-2015, 04:23 PM
lightning31659
My 1995 3.8l mustang was made in December of 1994 and is obdII
Old 09-24-2015, 07:22 PM
PNYXPRESS
PNYXPRESS's Avatar
This thread is 4.5 yrs old. I'm sure they have either figured out what obd system they have or got rid of the car.
PNYXPRESS is offline
Old 09-05-2017, 08:55 PM
Jaduty12
Jaduty12's Avatar
Default Questin
Originally Posted by NeoTokyo
You would have to do whats called a SplitPort Swap.
The motors are interchangeable but you will need to change a couple things and alter the wiring harness and get a tune.
Going to a splitport is suggested for more power and reliability as they dont have the head gasket problems that 94-98 do.
Your looking at about $600 ontop of the cost of the motor, roughly.
It can cost more if you upgrade things or replace the water pump and T-Stat, in fact a lot of places wont warranty the motor unless you replace the water pump and T-Stat.
With the splitport you get 40hp more (About 50hp since you have to get a custom tune from VMP and the use of your stock headers) and reduced chance of head gasket problems.
So he will go from 150hp to 200hp
Stock VS stock.
94-95 = 145hp (Singleport)
96-98 = 150hp (Singleport)
99-00 = 190hp (Splitport)
01-04 = 193hp (Splitport)
How hard will it be to put a 2003 mustang 3.8 motor in a 2000 mustang with 3.8 motor
Jaduty12 is offline
Old 09-11-2017, 05:23 AM
mustangman02232
mustangman02232's Avatar
Minor electrical work for the IMRCs if I recall, personally would look for a 4.2 out of an f/e-150, if you are going to do any kind of work for it
mustangman02232 is offline
Old 09-11-2017, 05:41 PM
Daehawk
Daehawk's Avatar
Nows the time to stick a Ford Thunderbird Supercoupe engine in it
Daehawk is offline
Quick Reply: Replacement 3.8L V6?
