Nitrous
#21
Well, most people are looking at nitrous as a cheap alternative. In which case I don't see most of the people buying new injectors & pump to make a dry kit that "safe". Of course with everything you have a chance of something failing , this is why they make safety switches
#22
You really don't need a larger fuel pump or injectors to run dry as dry shots are very low "boost" per say. You should, however, run a larger fuel pump with wet and depending on the shot load you may need injectors too. As stated just much more work needed with wet over dry.
#23
Well according to your standard fuel load calculator at 250 bhp (which would probably be what a 75 shot would yield) your stock fuel injectors "should" hold assuming you have 21 or 24lb I know the V6s had several different injector sizes. IDK what size the stock fuel pump is but generally a 110lb hr fuel pump will take that kind of power.
#24
