Engine Won't Turn Over!
Old 06-05-2011, 02:53 PM
Cinn
Cinn's Avatar
I meant on the car . Is it in the main fuse box or somewhere else?
Cinn is offline
Old 06-05-2011, 03:00 PM
The grey beast
The grey beast's Avatar
Oh haha, my bad man, and your users manual should show where its at
The grey beast is offline
Old 06-05-2011, 03:14 PM
Cinn
Cinn's Avatar
I don't have one bought it salvaged 8 years ago and never bought one, need to though.
Cinn is offline
Old 06-05-2011, 03:21 PM
NeoTokyo
NeoTokyo's Avatar
How did you bypass the PATS system without disabling your car?
I thought you had to use a tuner with that option to do that.
btw, if thats what was tripping it then your Theft light should have been blinking a code or on solid.
It would be interested to see exactly what was going on.
I have started having a random problem with PATS where I need to remove the key after it acts up, then put it back in and let it sit for a min in the ignition, then turn over to on without starting, wait a couple seconds more and THEN I can start it.
Not sure if the chipped key is failing or the sensor.
Crazy *** PATS problems. :P
NeoTokyo is offline
Old 06-05-2011, 07:24 PM
The grey beast
Cinn they are online man, just google it and then you can print it out
Old 03-15-2017, 09:26 AM
Bam2112bam
Bam2112bam's Avatar
Default No start
Originally Posted by kingalls
Car's been sitting for 8 months. It was running when I parked it. Battery is fully charged, all dash lights come on, but it engine won't turn over. It will run if I push start it. No power to the starter. Any ideas?
my car will only turn over if I take off the cover for the starter Relay and make the connection by pushing the contact together
Bam2112bam is offline
Old 03-15-2017, 09:28 AM
Bam2112bam
Bam2112bam's Avatar
Default Car wont turn over
please help
Old 03-15-2017, 12:03 PM
Daehawk
Daehawk's Avatar
Why not just replace that? You seem to know whats wrong with it already. Usually relays are not much.
Daehawk is offline
Old 11-23-2017, 08:15 PM
mezani
mezani's Avatar
Default How to disable the theft system
I am having the same issue, i took the starter out figured it was bad solenoid, had it tested and it was fine. Put it back together and it started but today it wont start. I bypassed the clutch switch. still nothing, looked at the wiring diagram and it looks like it is the anti theft system relay. This started happening after someone tried to to punch the trunk keyhole... Coincidence? 2000 v-6 manual transmission.
mezani is offline
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
KEM Motorworks
08-14-2015 10:13 PM
drumhedd2005
08-13-2015 09:59 AM
yurizx6r
08-11-2015 07:50 AM
Quick Reply: Engine Won't Turn Over!
