HELP! 00 3.8L 5 high idle, starting issue, smoke?
Old 06-17-2011, 04:24 PM
natejones
natejones's Avatar
Exclamation HELP! 00 3.8L 5 high idle, starting issue, smoke?
When i try to start the car, the first try it will not fire. It does cranck but will not fire. The second time it usually works. Sometimes i press on the gas lightly and that will help it on the second try. Also it seems to idle a little high, for EX: pushed in the clutch and it remained at about 1.5 - 2k RPMS. Also one of the biggest problems...When the car does smoke. 3 out of 4 times it will smoke for about 5 seconds and then stop. Its pretty heavy smoke, it is White not black, but cannot tell if it has a bluish tint to it or not. The battery, Alt, and starter have been checked and are fine. Any ideas?
natejones is offline
Old 06-17-2011, 04:26 PM
natejones
natejones's Avatar
Also the motor kind of rocks and shakes the car, like maybe its missing?
Old 06-17-2011, 04:35 PM
arabianobsession
arabianobsession's Avatar
I could be wrong but to me it still sounds like a head gasket issue, or it could be the valve seals are worn and leaking oil.
How long does your car have a high idle? 30 seconds, 1 minute, or longer?
arabianobsession is offline
Old 06-17-2011, 04:43 PM
natejones
natejones's Avatar
Sorry i forgot to include that, The head gasket is fine we tested that as well. if i come to a stop the idle will come down in no longer than 5 seconds. Thanks for your post! any other ideas?
Old 06-17-2011, 05:42 PM
WoahPony
WoahPony's Avatar
White smoke definitely means you're burning oil, just need to find out from where.
WoahPony is offline
Old 06-17-2011, 07:20 PM
natejones
natejones's Avatar
i can't really tell because i just bought the car, but it feels like it has NO power, any idea what a combo of all this would mean ?
Old 06-18-2011, 09:07 AM
arabianobsession
The last car I had that had your kind of issues (smoke, higher idle, no power), was a combination of a bad head gasket and a failing MAF sensor.
Old 06-19-2011, 10:15 PM
natejones
natejones's Avatar
fixed the smoke, there was no PCV valve. Easy fix. I think it was sucking oil through and getting into the intake?
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
YoungStangsMan
09-05-2015 07:01 PM
Calizic
08-28-2015 01:46 PM
overnight89
08-22-2015 09:02 PM
Quick Reply: HELP! 00 3.8L 5 high idle, starting issue, smoke?
