BANK 1 lean & bank 2 lean
hello my name is Ron,
I have a 1995 mustang 3.8 l. new reman engine error codes came up. have a hesitation have to feather the throttle at times. Also when car heats up it has a tendency to stall. Any help will be appreciated?
Exactly what codes is it throwing? Can't help without more info.
http://www.obd-codes.com/p0171
http://www.obd-codes.com/p0174
Both are indications of either the Mass Air Flow sensor is dirty and needs to be cleaned/replaced or you have a vacuum leak downstream of the MAF sensor.
Good luck...
Good luck...
anything after it.
Like the name says, IE your in a river fishing, you cast your line upstream and it floats downstream. You are the MAF.
The flow of air is the same.
The flow of exhaust is the same.
The filter is upstream of the MAF
The Throttle body is downstream of the MAF
The 1st O2 sensor is upstream of the cats
The 2nd O2 sensor is downstream of the cats
Hope that helped, sometimes you just need a mental image.
