SPUTTERING, NO ONE CAN FIND THE PROBLEM.
Old 08-13-2011, 06:36 AM
  #21
NeoTokyo
NeoTokyo's Avatar
You need cats because your spewing poison to say the least, if you want to talk about performance, legality and the huge fines you can get then thats another matter.
For your six, you will benefit from the backpressure of at least two cats.
You are also suppose to have 4 O2 sensors, two upstream and two downstream.
If you just have the rears unplugged your going to have problems too.
Set the system up correctly.
Think of it like this, if you set the system up correctly you can easily swap between your LT and stock setup when smog comes around every two years.
At the very least you will be smog legal in many other states, not killing your fellow drivers and your car will be happier.
NeoTokyo is offline
Old 08-14-2011, 07:01 AM
  #22
hernandez5
hernandez5's Avatar
Alright, what kind of cats are some good cats I hear that there is no such thing of HI FLOW CATS.Where would the other 2 O2 censores be located after the cats?should I let the shot provide the O2s or should I buy my own.
hernandez5 is offline
Old 08-14-2011, 07:09 AM
  #23
hernandez5
hernandez5's Avatar
Do I have to get the califronia legal cats or are they all the same
OSUTX440
Ohio Regional Chapter
03-15-2021 09:27 AM
Vrooom
02-21-2016 05:25 PM
bconboy
09-24-2015 01:55 PM
MasterLanMan
09-13-2015 08:21 PM
Brandonfilipponi@yahoo.com
09-12-2015 11:39 AM
Quick Reply: SPUTTERING, NO ONE CAN FIND THE PROBLEM.
