rotors?
Old 09-04-2011, 12:24 AM
Stein
Stein's Avatar
Originally Posted by petrock
Turning rotors does resurface them. It removes about 1 or 2 mm of metal from both sides, smoothing out the rotor etc.
Its the same amount of effort to remove old rotors and install new ones as there is in removing old rotors, bring to shop to turn/resurface, and reinstall. The latter costs a lot less, and there is no waiting for parts in the mail etc. Takes about 20 minutes to turn a rotor and only costs about $15-20 compared to the cost of a new set of good quality rotors.
I agree... A good parts house can usually do this for you too... The closest Napa to me does it for $15 per - much less than a new rotor of similar quality to your OE ones. I usually drop off the rotors, go to lunch, and then pick them up along with new pads. Make one trip out of it.
On that note, I might as well throw in my .02 and say that I will probably never pay someone else to do my brakes... They are super simple, especially with disk brakes.
Stein is offline
Old 09-04-2011, 05:21 AM
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
To answer the OP's original thought. You turn rotors every time you replace pads. Replace rotors when too thin to turn.
RyansQuick6 is offline
Old 09-04-2011, 10:40 AM
desertt5
desertt5's Avatar
O'Reilys by my house turns them for free. As for buying cheap rotors, you do get what you pay for. I have seen the $20 that could not be turned once. I personally went with Raybestos the last time I got some.
desertt5 is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
10-07-2015 07:02 PM
Omgitsa88Stang
10-05-2015 07:33 AM
09-16-2015 07:53 PM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: rotors?
