Electrical problem or fuel problem?
with an issue like this you must eliminate issues one at a time until you find the bad apple.
How many miles on the car? How is the car driven? (fast, slow, hard high revving?) does it only have a issue on high load circumstances? what kinda of tools do you have access to?[/QUOTE]
Tried numerous things man, tried new plugs, plug wires, coil pack, alternator, battery. i've been told that when your cats get plugged up they can cause almost a backfire and that tells the brain that your having a missfire. could be going crazy, im not sure. just don't wanna run it like this. thanks for the reply.
Not sure how that would happen. But if a cat was that clogged it would throw a O2 sensor code that the cat isn't performing properly.
