Symptoms of intermittent coil pack failure? - Page 3 - MustangForums.com
Old 10-27-2015, 11:01 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrain
Print Wikipost
Old 03-13-2012, 11:41 PM   #21
luvtheedge83
just to throw in an update. the stuttering under load and going uphill is gone. still have something going on with it sputtering while reving at idle. i might have to change the fuel filter. but the coil pack helped my fuel mileage come back too
luvtheedge83 is offline   Reply With Quote
Old 03-14-2012, 04:04 AM   #22
petrock
Quote:
Originally Posted by Somnambulator View Post
not sure how people spend $70+ for these ignition coil packs but they're all over ebay for half that.
Because you get what you pay for. Cheap aftermarket coil packs have a higher failure rate then Motorcraft coil packs.
petrock is offline   Reply With Quote
Old 03-21-2012, 08:18 PM   #23
djsysrq
I have the same problem, ive changed the spark plugs, plug wires, fuel filter, maf sensor and coil pack, nothing is helping, any ideas?
djsysrq is offline   Reply With Quote
Old 12-05-2012, 09:47 PM   #24
chriso
Default possible coil problem
I have found the problem to occur both under load and worse if it's very wet or foggy out. It also seems to occur when the car gets hot, this really leads me to believe that it's one of the coils... these symptoms are very indicative of an electric problem. I have ordered 8 coils from american muscle on the web for a really great price 269.95 done and out the door...the brand is accel super coil they are yellow with black boot. I really think that is the problem will let you all know soon, 4 days from now 12/03/2012 wed.
chriso is offline   Reply With Quote
Old 08-04-2013, 06:59 PM   #25
Kelly Pennay
Thanks for the thread guys I have had the same problem and just went and got the coil pack from Advance Auto and so far I am satisfied that was the problem. if it starts haunting me again I will let you know as this is a problem that comes and goes so time will tell all.
Thanks again
Kelly
Kelly Pennay is offline   Reply With Quote
Old 08-04-2013, 08:49 PM   #26
Torch_Vert
Torch_Vert's Avatar
Quote:
Thanks again
Kelly
Ditto. I've been having trouble with my '05 V6 since Thursday (which uses a similar coil pack). Had already ordered a replacement pack earlier this evening, but sort of comforting to hear the identical symptoms being caused by coil packs going south.
Torch_Vert is offline   Reply With Quote
Old 08-04-2013, 11:21 PM   #27
TomKat
tune up
TomKat is offline   Reply With Quote
Old 08-05-2013, 06:10 AM   #28
Torch_Vert
Torch_Vert's Avatar
Quote:
Originally Posted by TomKat View Post
tune up
Eh? What has a tuneup got to do with a coil pack failure?
In my case, the car had a "tuneup" less than a month ago (fresh plugs, wires, cleaned TB, MAF, Air Filter, new fuel filter)
Old 08-05-2013, 08:29 AM   #29
BabyGT
BabyGT's Avatar
Thanks again
Kelly
Not to scare you but if it does come back it could be the new coil again as well. Try to get at least Motorcraft or better. The "OEM replacements" from parts stores are known to be pretty sketchy. So don't go throwing money at other parts and get frustrated thinking at cant be the coil cause its new.
BabyGT is offline   Reply With Quote
Old 11-08-2014, 09:38 PM   #30
Patriotponies
Easy way to check the coil pack before springing for the part:
USE CAUTION! IT CAN SHOCK YOU IF YOU ARE NOT USING RUBBER GLOVES!
1. Crank the car and let it Idle
2. One at a time, pull the wire boots from the coil pack a little, and listen for the sound of an electrical arc
3A. If you hear the arc, return the boot to it's position
3B. If you do NOT hear any arc, pull the boot back a little past the connection and look for "lightning" to reach out and lick the boot.
4. You may have to follow procedure 3B with all boots, as a louder engine will mask the arc sound.
5. If the coil pack is bad, one or more coils will not arc or will have much less action than the others.
Patriotponies is offline   Reply With Quote
Labor Day Weekend Special Granatelli Sales GT S197 General Discussion 5 03-25-2016 08:01 PM
MSD 2 Step Rev Limiter firehorse02 Parts For Sale 1 11-16-2015 11:28 AM
Starting Issue svfetter 5.0L (1979-1995) Mustang 9 10-05-2015 11:39 AM
2001 V6 Sixer4Life New Member Area 4 09-28-2015 07:05 AM
Slight surge at 1500ish rpm lmurf60 4.6L (1996-2004 Modular) Mustang 1 09-24-2015 10:07 PM
01, 04, 2004, 39l, cobra, coil, coilpack, convertible, failure, mustang, pack, problems, svt, symptoms, test
