3.8l interchange ability between fords
Old 01-07-2012, 05:25 PM
Dimboden
Dimboden's Avatar
Default 3.8l interchange ability between fords
I have a 94 mustang coupe with a 3.8L. Will a 3.8L motor from a 91 thunderbird LX fit without modification? Are the heads the same, my 94 has headers but I don't think they are factory?
Dimboden is offline
Old 01-08-2012, 09:49 AM
mustangmike09
mustangmike09's Avatar
94-98 had shorties from the factory.
not sure on the 91, most likely yes since the supercoupe motor can be used in our cars it'll probably work as well.
mustangmike09 is offline
Old 01-08-2012, 01:53 PM
Dimboden
Dimboden's Avatar
Thanks for the info. So would the exhaust ports on the heads be the same between heads? I'm trying to see if the spark distribution system would match up since they are both OBD I computer systems. Any insight?
Dimboden is offline
Old 01-08-2012, 03:46 PM
mustangmike09
pretty sure a 94 mustang is obdII is itnot ?
Old 01-08-2012, 08:34 PM
Dimboden
Dimboden's Avatar
I thought the change over was 95-96
Dimboden is offline
Old 01-08-2012, 11:41 PM
Daehawk
Daehawk's Avatar
Almost positive it will have a different EGR system. But the engine should be the same.
Daehawk is offline
Old 01-09-2012, 04:38 AM
Dimboden
Dimboden's Avatar
thanks for your information, it sounds feasible.
Dimboden is offline
Old 01-09-2012, 10:44 AM
mustangmike09
well idk what your looking for exactly. But Id be looking for an actual replacement from your style mustang.
Cause Idk if your referring to everything, short or long block
Stang or F150 are the only blocks I know that should work. Have to worry about balancing and mounts, bell housing mounts, sensors ... etc etc
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
Granatelli Sales
01-20-2020 12:34 AM
mustangchef
09-04-2015 08:08 PM
AMAlexLazarus
AmericanMuscle.com
09-02-2015 08:59 AM
Quick Reply: 3.8l interchange ability between fords
