oil cooler install 01 v6
ok
i have a quesion...
i want to install an oil cooler on my 01 v6 that i am swapping into my 95.
basically i want to run the lines from the filter mount to the oil cooler in the radiator that i just put in.
i would like to use this part...any thoughts...opinions...better ideas???
http://www.ebay.com/itm/RED-ALUMINUM...item43aa9bff55
no, i am not running anything other than stock..no racing...just a daily driver.
i am thinking of going this route because i believe that it extends engine and oil life. this is based on my exp with my 99 blazer...it has roughly 230k on original 4.3l and i think its oil cooling system has helped, along with not beating the crap outta it.
i know some say no need for it...just looking for some pointers.
thanks guys for the input
i have a quesion...
My suggestion after years of working with the 3.8L is skip it.
And my other thought is when something says "FOR OFF ROAD USE ONLY" right in the discription, a daily driver / street car should turn the other way.
