3.8 auto to manual swap, almost done, just need a little help - MustangForums.com
Old 01-14-2012, 03:44 PM   #1
Bokrasawski
Default 3.8 auto to manual swap, almost done, just need a little help
Hey there, so this is my issue. I have a 97 3.8 (recently replaced) with a t5 (also just installed)... My problem is that when I drive, my speedometer is ridiculously far off from what I'm going, so far off that when I hit 36, the speedometer reads 115 and the governor kicks in I'm not sure how to approach this problem. also I am getting no temperature readout, the radiator fan isn't coming on, and while driving back from the parts yard today, the horn went off and wouldn't stop. what a nightmare. any help would be greatly appreciated
Bokrasawski is offline   Reply With Quote
Old 01-14-2012, 04:21 PM   #2
3.0Taurass
3.0Taurass's Avatar
New speedo gear in the trans?
3.0Taurass is offline   Reply With Quote
Old 01-14-2012, 11:28 PM   #3
stangant
stangant's Avatar
did you replace the ECU?
stangant is offline   Reply With Quote
Old 01-15-2012, 10:21 PM   #4
Bokrasawski
I didn't, I found the speedo sensor on the trans, so I disconnected it and am able to drive as I please, but no speed readout anymore, obviously. I'm trying to figure out which part exactly I need, I may just remove the sensor and bring it straight to a parts store and ask them to match it. I replaced the temperature gauge and still no temp readout, So I put the fan on a switch until I can figure out the problem. should I replace the ECU??
Old 01-15-2012, 11:02 PM   #5
stangant
stangant's Avatar
I have never done the swap so not 100% sure but you could always "borrow" an ecu from someone with a manual and see if it helps. I'm sure there has to be some sort of difference between the setups as I think on auto's you can adjust with a tuner... but again not sure don't have an auto or have ever done this swap.
Old 01-16-2012, 09:21 AM   #6
Chromeshadow
It's cool that you made the switch, how does performance rate now that you have the 5 speed?
If you can't figure it out, you could get a Garmin GPS with a MPH readout and forget about the speedometer.
Chromeshadow is offline   Reply With Quote
trans swaps 97SN95GT 4.6L (1996-2004 Modular) Mustang 4 09-13-2015 10:45 PM
Cold air intake cause p1405?? J.casone400 General Tech 0 09-12-2015 11:01 PM
Classic Auto Air Feedback fastbackford351 Classic Mustang General Discussion 2 09-12-2015 10:42 AM
No power from my 3.8 94stangnewbe V6 General Discussion 0 09-07-2015 08:39 PM
Opinions regarding 2015 Base Mustang GT w/19' wheels & Ford Racing Handling pack? mungodrums Suspension 0 09-07-2015 08:22 PM
04, 2000, 2004, 3.8 t5 speedometer broken, 38, 95, auto, automatic, conversion, manual, mustang, sn95, speed, swap, v6
