My mustang is acting weird
Why is my exhaust leaking water, and has very little power, and my engine is shaking more than usual. Earlier i put on new spark plug wires, a coil pack and CAI. I also tried to put on underdrive pullies but my crankshaft bolts refused to budge. Did i do something in the process of putting the pullies on, I literally drove the car before i put everything on. Somebody help!!!!
I had to replace my spark plug wires and coil pack before. My engine would shake, idle really low, skip, cut off, or even make a popping noise when i excellerated. all that just because one wire! my suggestion would be to check and make sure all your wires are firing right and that they arnt defective. As of the water out of the exhaust ive seen tons of cars do that (so im guessing that is normal unless it is an excessive amount). My other suggestion would be to take it to a machanic (not ford) or try autozone, they can plug a senser up to it and it could tell you whats wrong. thats how my machanic found out it was my spark plug wires and coil pack. Hope this helped you some! good luck!
No im not losing any liquids at all. im almost positive it has to do with the spark plugs now. it is doing all the things that were described in the first reply to this thread, but i have no power at all to drive, it stays on but wont drive. i have the spark plug wires plugged in differently into the coil pack than previously, i dont have all the passenger side wires on one side of the coil pack and same goes for the driver side will this make a difference.
The wires have to go in a specific order on the coil pack. Each tower on the coil pack corresponds to a specific cylinder. If you get them mixed up then you can have the problems your describing and potentially damage the motor. There should be numbers listed on the coil pack. Those numbers indicate which cylinder that tower is supposed to connect to.
I couldn't find any numbers on my coil pack so I looked up the diagram for cylinders to coil pack wired it up the right way it has more power but still very underpowered and still making the popping noise though the excessive shaking at idle has stopped
