I can't turn off the engine - MustangForums.com
Old 03-30-2012, 02:27 PM   #1
adriankapustik
Default I can't turn off the engine
Can anyone help me? When I try to turn the engine off the key seem to loose fair bit of resistance. Nothing happens even when I take the key out. the engine is running untill I cut off the fuel from the boot. I took out the key cylinder and it seems OK. I tried to buy new cylinder from key specialist but he insisted that in my case new cylinder won't help. Please advice. many thanks Adrian
adriankapustik is offline   Reply With Quote
Old 03-30-2012, 02:39 PM   #2
belairbrian
He is correct. the failure is most likely the pin between the lock cylinder and the ignition switch however it could be a failure of the actual ignition switch.
The lock cylinder moves the pin which moves the switch. The pin is NOT part of the lock cylinder. It is also NOT part of the ignition switch. Rather it is part of the actuator assembly.
If you are able to restart the car again but still can't turn it off, then I would suspect the switch has worn or broken where the pin connects.
belairbrian is offline   Reply With Quote
Old 03-30-2012, 03:10 PM   #3
adriankapustik
Quote:
Thank you, and YES I can start the car over and over again :-) it seems that the car is in stage as if you have the key in ON position constantly. I need to disconect the battery to leave car completely OFF.
Old 03-30-2012, 03:25 PM   #4
adriankapustik
And please can you tell me how to get to this pin? thanks Adrian
Old 04-02-2012, 06:22 AM   #5
adriankapustik
For all of them having the same problem here is the link to solution. These guys are great. many thanks.
so here is the link
http://www.steeringcolumnservices.co...structions.php
Old 04-02-2012, 12:51 PM   #6
jkeaton
jkeaton's Avatar
My car had a jacked up ignition lock cylinder when I got it and it could not be fixed. I got a new column from a pull-a-part place for $25 and the problem was solved.
jkeaton is offline   Reply With Quote
Did a few mods this summer... drfister 2005-2014 Mustangs 9 09-04-2015 07:47 AM
1989 starting problems, engine won't turn over. KEM Motorworks 5.0L (1979-1995) Mustang 20 08-14-2015 10:13 PM
Fuel pump not priming!! HELP drumhedd2005 2005-2014 Mustangs 2 08-13-2015 09:59 AM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 12:59 PM
Oil pressure freak out yurizx6r 5.0L (1979-1995) Mustang 14 08-11-2015 07:50 AM
engine, mustang, turn
