New kid on the block, with another exhaust question.
Hey everybody, im new here. I just picked up my mustang for an awesome price, and my finger are itching to do some mods.
The first thing I want to do is some exhuast. Im going to keep it single but im going to run 2.5 inch exhuast from the y pipe. Does anybody have a stock exhuast diagram, I was going to do this myslef, but as I got under the car I see right where the pipe meets the muffler, there is two small bends. id like to know the degrees of the bends, to see if I can do this myself. I might end up taking it to a shop... but that might be a little pricey?
Also im still debating if I should go with a low deep sounding dynomax turbo muffler, or a thrush muffler. Anybody have any good sound clips?
you can look at the setup here, http://techweasel.blogsome.com/2009/03/07/retrolicious/
I have a 4inch turn-down on mine...Sounds really good compared to the duals. Duals sound too much like coke cans to me. Suggestion though. If you get the turn-down, Id suggest getting the hi-flo cats from American Muscle. My friend has a 3inch turn-down and put those on there and it sounds mean. As good if not better than a standard GT exhaust. The pipe itself was only about $180 (I know a guy). Not too sure what it is exactly because I didnt do any of the work myself, just know its a Flowmaster. Hope that gives you a little insight.
Yeah, I dont like how duals sound at all. Your right haha they sound like you just stuck some over sized coke cans on the car. Ill leave the stock cats on there. If anything Ill get bored and gut them, but they probably dont flow that bad, id be afraid gutting them would give a negative affect to pack pressure.
I have all the piping, I just got to weld the pipes to the glasspack and find a flange so Ill be able to bolt it up to the stock exhuast.
no just no 0_o
Duals ...
Their are so many different options I dont know why your saying this coke can **** ?
Divorced, H, X, Pro; mid pipes make a HUGE difference in the way it will sound as well as mufflers choice.
Duals ...
Okay well I at least knew it had to exit from under the car to pass visual inspection. It's also ticketable in most states. You can get away with duals because there was a version (gt) that came with duals factory.
