Engine service light Intermittent running rough
Old 05-13-2012, 01:23 PM
sealpt
sealpt's Avatar
Default Engine service light Intermittent running rough
Hi,
New to the site here. So, my wifes 2002 V-6 mustang has had the engine service light come on recently. She tells me that sometimes she starts the car up and it runs rough and the engine service light will come on. The light then goes out and the car runs fine. It is very intermittent.
Does anybody have any ideas?
Thank you,
Shawn
sealpt is offline
Old 05-13-2012, 09:30 PM
JeffBall
JeffBall's Avatar
Get the code read when its on, it might be sitting in the memory, so you could try taking it to an autozone/advance and let them read it. Hard to give suggestions for a CEL without the code.
JeffBall is offline
Old 05-13-2012, 09:36 PM
sealpt
sealpt's Avatar
I didn't realize it kept a record of that sort of thing. I'll get the code and get back here with the results.
Thank you,
Shawn
sealpt is offline
Old 05-14-2012, 11:30 AM
JeffBall
JeffBall's Avatar
Yeah, if you dont disconnect the battery or anything, sometimes it will store it in the memory, a specific one i had, P1130 sat in the memory although my CEL wasn't on. I have a handheld tuner and was messing around with it, and the code was sitting there but no CEL, i thought maybe my bulb was out in the cluster, then like a week later it came on. Turns out my PCV valve on the passenger side was out. lol
JeffBall is offline
Old 05-15-2012, 10:01 PM
sealpt
sealpt's Avatar
Well, I went to autozone and the codes it gave out are 301 and 316
301: Cylinder misfire detected -cylinder number 1
Ignition system fault-spark plug, ignition wires, coil.
Vacuum leak
Injector fault
High or low fuel pressure.
316 Crank sensor position sensor signal is monitored for errors.
Crank sensor defective
Check connector and wiring to sensor
Check trigger wheel for damage.
Now the thing is, this has only happened a couple of times and it lasts for like 5 seconds and is fine.
Which do you think would be most likely the problem?
Thank you,
Shawn
sealpt is offline
djbigskrilla
09-20-2022 01:04 AM
1987gt40ttopt
08-28-2015 10:49 PM
kevans79@yahoo.com
08-18-2015 08:16 AM
fdnyems19
08-13-2015 09:36 AM
Jacob4589
08-08-2015 11:00 AM
Quick Reply: Engine service light Intermittent running rough
