What transmissions can I use for a swap - MustangForums.com
Old 05-12-2012, 09:50 PM   #1
brice27332
brice27332's Avatar
Default What transmissions can I use for a swap
Ok, first let me apologize if a similar question has been asked and answered in a previous thread. I have been trying to use the search function but anything I search for always returns no results.
I have an automatic 2001 Ford Mustang Convertible with a 3.8l motor. I have a picture of it on my page if you would like to see it. It is my intention to do a swap to a manual transmission in the near future as one of my first mods. What I would like to know is will the T5 in the Fox body Mustangs swap without many problems?
I know there are a number of transmission that I could use, I am just not sure if the older models will fit or if I should even venture to place an older style trans in the newer ride. Please advise. Thanks.
brice27332 is offline   Reply With Quote
Old 05-12-2012, 09:56 PM   #2
LilRoush
LilRoush's Avatar
The T5 from a fox will fit, but you need to use the 94/95 bell housing if I remember correctly. I'm sure someone will post quickly with better info. It's been several years since having a trans out of a V6.
LilRoush is offline   Reply With Quote
Old 05-12-2012, 10:00 PM   #3
jthorn9
The Godfather
jthorn9's Avatar
You need a 94/95 belhousing and to modify driveshaft length. The foxbody T5s have a slightly shorter driveshaft than their 94+ counterparts.
jthorn9 is offline   Reply With Quote
Old 05-12-2012, 10:12 PM   #4
brice27332
brice27332's Avatar
So does this mean I could use the fox body drive shaft as well?
Old 05-13-2012, 10:23 PM   #5
sonicblue2002
I'm not sure about this, but the fox bodies have a mechanically driven speedometer and the 3.8 has electronic after 1999, could be an easy fix or could be a problem, not sure.
sonicblue2002 is offline   Reply With Quote
Old 05-14-2012, 12:54 PM   #6
automaniak22
well I have a question... what transmission is a direct replacement for the t5 and is the t5 the only transmission offered in the 3.8 as far as a manual?
automaniak22 is offline   Reply With Quote
Old 05-14-2012, 01:34 PM   #7
jthorn9
The Godfather
jthorn9's Avatar
Well, you need a 99-04 manual transmisson. Only those are the "direct swap".
Old 05-14-2012, 03:28 PM   #8
LilRoush
LilRoush's Avatar
Quote:
Yes, the T5 was the only manual offered in the V6.
Old 05-15-2012, 10:03 AM   #9
automaniak22
ok what transmission can handle hp levels around 500? I'm looking at pulling the crank from my old sc and getting a procharger kit with upgraded supercharger that can push for more boost hopefully ranging around that with heads headers and so on. and I know that the t5 wont last long on that level.
Old 05-15-2012, 04:33 PM   #10
brice27332
brice27332's Avatar
Well you can use the T56 or the Tremec TR-3560 or T3550
Terminated Whipple GT battles '13 GT500 on E85 Bokeo Street/Strip 6 10-10-2015 09:28 PM
Starting a new project....could use some input. Matt's 95 Stang 5.0L (1979-1995) Mustang 2 10-05-2015 08:16 AM
Rough idle and vibrating 4cylinderplus2 V6 (1994-2004) Mustangs 9 09-30-2015 06:26 PM
Need to rebuild the automatic transmission 1996 GT wraith777 General Tech 1 09-28-2015 11:49 AM
2002, 95, fit, fits, ford, mustang, t3560, t5 transmission, t56, transmission, transmission swap, transmissions, v6, vehicles, year
